Gaz_R Posted April 24, 2005 Share Posted April 24, 2005 Hi- As per the thread I started the other day I have had my Elise go through a used car check before signing on the dotted. Nick Whales found the following, nothing major - would appreciate any comments: -Slight rust inside front headlights (presume there is a metal ring around light?) -Rear bump-stops splitting (how easy is this for me to replace myself?) -Exhaust Flexi pipe webbing broken (as above..) -Slight play in steering rack (rack replaced by Horizon a couple of months ago so will take it back under warranty to be sorted) -Oil leak - probably from rocker cover gasket (I am told by a mate this is not under pressure so won't bother about it....) -Exhaust knocking on under tray - (assume I need to just lower it a little and re-fix???) So all in all just little problems so all is good with me getting my first Lotus. Can't wait. Already talking to mate with Caterham about doing Lands End - JoG. Any comments on getting the above sorted??? C-ya. Link to comment Share on other sites More sharing options...
Scott_Mac Posted April 25, 2005 Share Posted April 25, 2005 Hmm, headlights are reasonably easy - a bit of a pain, the units are about £40 each. Bump stops - <shrug> Flexi section - expensive if it goes. Steering rack - sorted as you say. Oil Leak - err, any kind of oil leak is bad in my book! Exhaust - sounds like an odd one, maybe the rubbers gone? Link to comment Share on other sites More sharing options...
Gaz_R Posted April 26, 2005 Author Share Posted April 26, 2005 Thanks for that. I think some remedial action will be taken on the flexi. Any other comments folks? Link to comment Share on other sites More sharing options...
