Bramble111s Posted May 10, 2004 Share Posted May 10, 2004 Misjudged a right turn junction and must have caught the rear offside wheel. At the time it seemed like a mighty wack, but I can't see any marks on the alloy. Having had my geo done 3 months ago, I would prefer not to spend another £100 on checking it. But with my Trackday booked, I would have peace of mind knowing I hadn't buggered it up. I presume their is no other way to check and it is probally out???? It seems like this is an expensive mistake I have made.... Link to comment Share on other sites More sharing options...
Scott_Mac Posted May 10, 2004 Share Posted May 10, 2004 You have been busy haven't you! Have you tried driving along in a straight line and letting go of the wheel, probably less of an issue with a rear wheel, but see if it pulls you anywhere... also try accelerating to about 50 in 3 rd gear and lifting hard on and off the throttle - used for testing rear toelinks, but may show something up here too.... Otherwise it may be tricky to test. Link to comment Share on other sites More sharing options...
Bramble111s Posted May 10, 2004 Author Share Posted May 10, 2004 Hmm, I did try letting go of the wheel and seeing if the car steered off somewhere, norfolk roads are not the best to test this though, will have to find a flat bit and try again. Will have a go with your 50 on off bit as well. thanks! This is not the kind of busy I prefer.. Link to comment Share on other sites More sharing options...
Kris H Posted May 10, 2004 Share Posted May 10, 2004 Bramble - FWIW if you're not sure then £100 quid or not I'd get it checked - will be a lot more expensive if you go off on a track because of un predicatble handling, and maybe quite dangerous too. Before I got mine done it felt OK but after I couldn't believe how different it was. If there's no mark though are you sure that you hit the alloy and didn't just smack the tyre? If it was just the tyre it's more likely to have absorbed the impact better I would have thought. Link to comment Share on other sites More sharing options...
Bramble111s Posted May 11, 2004 Author Share Posted May 11, 2004 It could well have been the tyre, frankly I was amazed I hit anything, I can only think as the I was the junction was uphill going to a flat road that I turned in like a muppet to hit the kurb, certainly surprized me. That or there was a great solid hedgehog just away from the kurb! I agree with you entirely, as I know the transformation a geo made to my car, as I only had it done in Feb! I have asked Stratton for a price to look at it. Noticed on my service report all my gaiters are perished and split as well, so have asked for a price to replace these as well. I presume they extend the life of the parts they cover and should be done, rather than left? Link to comment Share on other sites More sharing options...
Ladders Posted May 11, 2004 Share Posted May 11, 2004 Bramble, I'd have thought if the car feels ok then you should be alright. Like Kris said, if it's just the tyre that was hit it could be ok. Although it could be worth going back to have it checked where you had the geo done, surely they won't charge you £100 just to check it's ok? As for the gators, you will need to have them sorted to pass your MoT I should think. Link to comment Share on other sites More sharing options...
Bramble111s Posted May 11, 2004 Author Share Posted May 11, 2004 Yes, I am hoping Stratton will give it a quick look for free or £20 or so, fingers crossed. Gaitors, ok, will leave till MOT then, unless anyone thinks this will mean more wear on ball joints etc? Link to comment Share on other sites More sharing options...
Ladders Posted May 11, 2004 Share Posted May 11, 2004 I'd get someone to check them before the MoT, it's a real pain if you fail it and have to get fitting new ones sorted and can't drive the car! Took me about 3 weeks to get mine through emissions for the MoT! Real pain! Link to comment Share on other sites More sharing options...
Scott_Mac Posted May 11, 2004 Share Posted May 11, 2004 Of course, if you came to the 1stLotus day, i'm sure Walshy could look for you Link to comment Share on other sites More sharing options...
Simon G Posted May 11, 2004 Share Posted May 11, 2004 You need to make sure you haven't bent anything, you should have the suspension components checked, no mistake. Link to comment Share on other sites More sharing options...
Maxf Posted May 11, 2004 Share Posted May 11, 2004 I hit a kerb with a rear wheel and dented it up pretty well (had to buy a new wheel) - you couldn't see any damage until the tyre came off (it kept going flat). 2 geo's said it was fine afterwards. Well worth checking out properly - it will be much dearer to fix the slightest of track incidents than a geo is now. Link to comment Share on other sites More sharing options...
