Jamo Posted August 21, 2006 Share Posted August 21, 2006 Can anyone shed some light as to why mine won't come out? The service manual helpfully reads: 'manouvre the assembly out of the crossmember', but looking along the rack it looks as though the splined pinion shaft is too big to fit through the hole. I struggled with the rack for about an hour, pulling in both directions and rotating it, am I missing something? Link to comment Share on other sites More sharing options...
dss123 Posted August 21, 2006 Share Posted August 21, 2006 Tell me about it Jamo! - just seems like it can't be possible to get it out eh? I bet you are trying to remove it from the off side? right? Sounds weird but try removing it from the near side (passenger side) and for some reason that I can't fathom it comes out easily - well maybe not easily but just a little wiggle and out she pops! Give it a go. Dunc Link to comment Share on other sites More sharing options...
Jamo Posted August 21, 2006 Author Share Posted August 21, 2006 Tell me about it Jamo! - just seems like it can't be possible to get it out eh? I bet you are trying to remove it from the off side? right? Sounds weird but try removing it from the near side (passenger side) and for some reason that I can't fathom it comes out easily - well maybe not easily but just a little wiggle and out she pops! Give it a go. Dunc That's right offside has been my main focus, i'll refocus the efforts to the nearside and see what I can do! The main problem I can see is being unable to get decent purchase on the rack itself, as the TREs just move about and rotate freely!!! I shall report back after having a go tonight! Link to comment Share on other sites More sharing options...
ratherbewindsurfing Posted August 21, 2006 Share Posted August 21, 2006 There are some redundant rivnuts that make removing the rack virtually impossible without removing them. I think the rivnuts were inserted after the rack was put in at the factory. I think they are for the battery holder in left hand drive format Best of luck!! Link to comment Share on other sites More sharing options...
Jamo Posted August 22, 2006 Author Share Posted August 22, 2006 There are some redundant rivnuts that make removing the rack virtually impossible without removing them. I think the rivnuts were inserted after the rack was put in at the factory. I think they are for the battery holder in left hand drive format Best of luck!! You mean these: They certainly caused trouble as the pinion wouldn't go back far enough: However, I tried from the nearside, got my hand in and viola: The trick was to get my hand in and grip the rack itself, rotate it whilst moving back and forth along the crossmember! Link to comment Share on other sites More sharing options...
