mambosasa Posted March 17, 2006 Share Posted March 17, 2006 The Brains of MLOC. How do I remove the handbrake cover? I can't seem to be able to slide it over the handle. Am I missing something or do I need to apply brute force? I need to remove it this afternoon so I can take it to Donny tomorrow. Cheers all. Link to comment Share on other sites More sharing options...
Heph Posted March 17, 2006 Share Posted March 17, 2006 I believe the Handle should be taken out. It must be removeable since there's aftermarket ones... I can't tell you how since I haven't done it... If I find something in the service manual, I'll come back to you Link to comment Share on other sites More sharing options...
Martin R Posted March 17, 2006 Share Posted March 17, 2006 Knowing Lotus its probably glued on. Give it a gentle tug Link to comment Share on other sites More sharing options...
mambosasa Posted March 17, 2006 Author Share Posted March 17, 2006 Knowing Lotus its probably glued on. Give it a gentle tug <{POST_SNAPBACK}> I have pulled, pushed, rocked, tugged and nothing. There has to be an easier way. I just don't want to force it and all end in tears. Link to comment Share on other sites More sharing options...
sootysteve Posted March 17, 2006 Share Posted March 17, 2006 if its the horrible black plastic sleeve your on about? I did mine with a stanley knife one good cut from top to bottom and it just pulls off. then replace it with a nice alloy one ! hope this helps Link to comment Share on other sites More sharing options...
mambosasa Posted March 17, 2006 Author Share Posted March 17, 2006 if its the horrible black plastic sleeve your on about? I did mine with a stanley knife one good cut from top to bottom and it just pulls off. then replace it with a nice alloy one ! hope this helps <{POST_SNAPBACK}> Yeah, its the original black handle. I guess I should get my credit card ready to purchase a new one tomorrow. I will go and try that. Thanks all. Link to comment Share on other sites More sharing options...
sootysteve Posted March 17, 2006 Share Posted March 17, 2006 no worries that'l do it. sounds sad but go on sun, i'll meet up on the way Link to comment Share on other sites More sharing options...
Mark H Posted March 17, 2006 Share Posted March 17, 2006 As said above, Stanley knife down the line on the plastic will remove the handbrake handle. Be careful not to slip or you will mark your handbrake/cut off your arm Link to comment Share on other sites More sharing options...
mambosasa Posted March 17, 2006 Author Share Posted March 17, 2006 All done . I tried the Stanley knife approach and feared for my life. So out came my trusted Dremell. It took about a minute to slice its way through the plastic and after the smoke cleared, it was just a matter of pulling the handle off. Much safer method I thought. Thanks all. Now, where is that Visa... Link to comment Share on other sites More sharing options...
Jonathan E Posted March 17, 2006 Share Posted March 17, 2006 Dremel, Fantastic tool Regards Jon Link to comment Share on other sites More sharing options...
mambosasa Posted March 17, 2006 Author Share Posted March 17, 2006 Dremel,Fantastic tool Regards Jon <{POST_SNAPBACK}> One of the seat bolts gave up on me when I was trying to remove the seat. I didn't have a chance once I indroduced it to the Dremel. Nice! Link to comment Share on other sites More sharing options...
