frank7 Posted August 12, 2022 Share Posted August 12, 2022 This was a perplexing problem that produced a lot of raised eyebrows. The Speedo and Tacho were flicking alternately from zero to near vertical and back every few seconds and all other lights were inoperative although indicators worked along with the security alarm/immobiliser warning light; everything else was blank. Aaargh! But fret not... the solution was remarkably easy. Simply disconnect the negative battery connection and reconnect about a minute later and hey presto, the instruments were all working correctly again. WARNING: Do not disconnect the battery immediately after turning off the engine! You need to give it 45 minutes or longer to settle after the ignition is switched off, otherwise you will get a warning light and perhaps other issues when you try to reconnect. Link to comment Share on other sites More sharing options...
Lithopsian Posted August 12, 2022 Share Posted August 12, 2022 45 minutes! Perhaps that's how long it takes for the capacitors to drain and the thing to really be powered down? Link to comment Share on other sites More sharing options...
frank7 Posted August 12, 2022 Author Share Posted August 12, 2022 Yes, sounds a likely explanation. Link to comment Share on other sites More sharing options...
Eric Posted August 25, 2022 Share Posted August 25, 2022 I had exactly this problem on my previous Elise. It was a real head scratcher, and I even took a video of it happening! Matt at Lotus Silverstone provided the solution though, and that, again, was exactly as you described - disconnect neg terminal, wait for a bit and then reconnect. Worked a treat. Link to comment Share on other sites More sharing options...
frank7 Posted August 25, 2022 Author Share Posted August 25, 2022 Interesting. The problem was solved then but the mystery remaining is… what caused it. The fix worked but I’d prefer to avoid it happening again just in case the procedure doesn’t work next time! 🤞 Link to comment Share on other sites More sharing options...
gallikev Posted August 27, 2022 Share Posted August 27, 2022 Hi a very interesting solution to a problem my issue is as follows after over winter storage on starting up everything was ok except no instruments on the binnacle working speedo / Rev counter /indicators blank removed all the fuses one by one cleaned and checked all ok issue disappeared, I thought haven’t used the car in the dark until last night everything ok but no binnacle/ dashboard lighting speedo etc indicator all lights exterior ok removed the fuses again and checked all ok but still no binnacle lights will try the negative terminal fix later suppose it could be just blown binnacle/ dash light bulbs any other ideas welcome folks its a 2008 S2 Exige supercharged thanks Link to comment Share on other sites More sharing options...
