hotpurple Posted June 23, 2021 Share Posted June 23, 2021 Hi all, My S2 Elise has developed a curious issue where the CEL is permanently lit and the fan runs from about 30s after the engine starts (stone cold) to a few seconds after the engine stops. Any ideas what to look for to fix it? There’s no codes shown when I plug the code reader into the OBD port. Link to comment Share on other sites More sharing options...
MrWill Posted June 24, 2021 Share Posted June 24, 2021 Hi hotpurple I'm no expert on elec-trickry but I've usually resolved issues before getting an expert in by just doing the basics Check all your connections for good fit and corrosion. Check for good earth etc If it was me I'd summise the fan coming on 30s after engine on means the ecu thinks the engine is hot so why not the obvious of a faulty temp sensor on the engine sending a false signal? Good luck MrWill Link to comment Share on other sites More sharing options...
hotpurple Posted June 24, 2021 Author Share Posted June 24, 2021 Thanks for the advice, you’ve had pretty much the same ideas as me. We’ve changed the temperature sensors (both of them) so my only thinking now would be a dodgy connection in the loom somewhere. Luckily, I have a OBD code reader that can show live values from the various sensors on the car, so I’m going to plug that in and see if the ECU thinks the temperature is doing something odd (open circuit maybe). Link to comment Share on other sites More sharing options...
