dobber82 Posted December 1, 2020 Share Posted December 1, 2020 Another one ... just looked at the engine and noticed the attached hose isnt within the clip ... I am guessing it should be!?! Link to comment Share on other sites More sharing options...
timbo Posted December 2, 2020 Share Posted December 2, 2020 I may be seeing this wrong, here, but it looks to me like the hose itself is in the wire clip - it's just the odd length of overbraid sleeving that isn't? Link to comment Share on other sites More sharing options...
richbk Posted December 7, 2020 Share Posted December 7, 2020 Thats a precision cut, perfect length overbraided sleeve i am sure.....just probably on the wrong hose !!. Yes as said the clip is holding the hose fine, its a cleaner fit just placed over the hose rather than trying to clip the sleeve too. You could add a wrap of heat resistant black tape to the ends of the sleeve if you want to ensure it remains in situ over time. Link to comment Share on other sites More sharing options...
MG4Lotus Posted December 7, 2020 Share Posted December 7, 2020 Is the sleeve meant to prevent the hoses rubbing together? The other hose, should that be fully seated? and clipped? Link to comment Share on other sites More sharing options...
Lithopsian Posted December 8, 2020 Share Posted December 8, 2020 That is the vacuum hose to actuate the supercharger bypass valve. Doesn't need a clip. You could try seating it more fully if you want, but should be OK as is. I don't think most Exige 350 owners work on their cars much, so technical knowledge is probably a bit thin on the ground. Not sure why the other hose is sleeved. Do the two hoses touch? Link to comment Share on other sites More sharing options...
