Foley Posted July 1, 2020 Share Posted July 1, 2020 Hi, My S2 Exige S original ECU has already been mapped as part of the charge cooling upgrade. It's not perfect, stalls sometimes at idle and keeps throwing up an intermittent fault code. The previous owner suggested that it's due to the map. I could do with getting it on the rollers and mapping again. Are there any local ish places that have managed to get into the standard ECU? Seems as though there's plenty down south but I'd prefer to use someone local if possible. Thanks Mike Link to comment Share on other sites More sharing options...
Alex B Posted July 1, 2020 Share Posted July 1, 2020 I'm pretty sure that the standard S2 ECU cannot be mapped due to being locked by lotus. Link to comment Share on other sites More sharing options...
collieek Posted July 2, 2020 Share Posted July 2, 2020 I think this is a common problem with the s 2 Exige has your car a aftermarket air filter on it, Mine does the same now and again it helps if the air intake is cleaned, I heard if an aftermarket filter is used with too much oil it can cause this. Mine has been checked by several different garages and they have not found anything wrong. Link to comment Share on other sites More sharing options...
Foley Posted July 2, 2020 Author Share Posted July 2, 2020 Thanks fellas. My car has the TRD airbox. Will take a look at it. Looking through the archive on SELOC it's clear that there were problems remapping the EFI ECU but there's quite a few places who have successfully cracked it. It looks like Sinclairs remapped mine originally. I think they now known by some other name. Link to comment Share on other sites More sharing options...
