collieek Posted June 5, 2020 Share Posted June 5, 2020 Can anyone recommend a competent windscreen fitter who will come out to your house and replace a screen? I am not going through the insurance company. Link to comment Share on other sites More sharing options...
winthattt Posted June 5, 2020 Share Posted June 5, 2020 I took my s1 to Gav so he could move the clam and then autoglass did it (under Gavin’s supervision). I’m not sure I’d trust a screen fitter to release a clam. An s2 is much easier. Link to comment Share on other sites More sharing options...
collieek Posted June 6, 2020 Author Share Posted June 6, 2020 The clam is off at the moment I have just had the original one painted so it is just screen supply and fit. I have found a couple of people who sound ok one in Lincoln and one from Mansfield who will come out to my house. The screen is for my S1. Link to comment Share on other sites More sharing options...
Lithopsian Posted June 6, 2020 Share Posted June 6, 2020 Autoglass are often recommended, they are all over. Your experience may vary depending on just which branch you get. Quiz them a little and try to get someone who has fitted to an Elise before. An experienced fitter (or more likely two) will be able to fit the screen without completely removing the clam. Unless the bolts are seized, they can easily be loosened and the clam lifted slightly at the front edge. Make sure the mirror is fitted in the right place (ie. not the middle!) and everything else is pretty standard. Paying one person to remove the clam and another to fit the screen could get pretty expensive if you're paying yourself, but might help your peace of mind if you have a trusted local mechanic. Or you can remove the clam yourself. It isn't hard on an S1, just a bit time-consuming. Well worth making sure all the bolts are free and greased, even replaced if necessary. The fusebox rawlnuts are almost certainly rusted beyond use. Link to comment Share on other sites More sharing options...
winthattt Posted June 10, 2020 Share Posted June 10, 2020 If the clam is off the fitting should be ok. Whilst the screen is the same for the S1, S2 and S3, I believe they have to remove the trim from the screen to install it on an S1. As suggested above, ask if they have done it before. In my case they said yes and wanted someone else to move the clam, so I believed they had done it before. Link to comment Share on other sites More sharing options...
collieek Posted June 11, 2020 Author Share Posted June 11, 2020 I have found a couple of people quite local who will supply and fit at my house both have experience, between 360 and 500 depending on glass manufacturer. Autoglass wanted 1100 to start with then came down to 800. Link to comment Share on other sites More sharing options...
AlanS1 Posted June 12, 2020 Share Posted June 12, 2020 That is a big differance. Would you mind sharing for future referance? Link to comment Share on other sites More sharing options...
Phil S1 Posted June 12, 2020 Share Posted June 12, 2020 I don't know whether you know but there is a heated screen available for the S1. I've never experienced one personally but it may be worth considering... https://www.heatedwindscreen.com/acatalog/lotus-elise-mark-1-heated-windscreen.html Link to comment Share on other sites More sharing options...
Elisemadray Posted June 12, 2020 Share Posted June 12, 2020 On 11/06/2020 at 16:51, collieek said: I have found a couple of people quite local who will supply and fit at my house both have experience, between 360 and 500 depending on glass manufacturer. Autoglass wanted 1100 to start with then came down to 800. is it not covered on your insurance? Link to comment Share on other sites More sharing options...
collieek Posted June 13, 2020 Author Share Posted June 13, 2020 No unfortunately car has been off the road for a year or so while I fitted the electric water pump and the original front clam. Big mystery how the screen has been damaged think it might have had damage and it just went with the cold during the winter. Link to comment Share on other sites More sharing options...
