Mrker60 Posted March 4, 2020 Share Posted March 4, 2020 Hi.I would like to recline my seat . If i get the seat in the best clutch posistion I feel like i,'m sat up strate. It would be perfect if i could recline a bit any options maybe longer bolts with some spacers at front ? If i got the ideal position i could get a mate to cnc 2 spacers with a slope to them ? Link to comment Share on other sites More sharing options...
JsExige Posted March 4, 2020 Share Posted March 4, 2020 I also want to do this. My drivers seat is on sliding rails which I like. I’d just like to raise the front 10mm or so. I think nylon spacers/washers might do the trick. Link to comment Share on other sites More sharing options...
Daveb99 Posted March 4, 2020 Share Posted March 4, 2020 Spacers will work. I used 5mm spacers at the front recently so that the mechanism clears my carpets when sliding the seat forward. Link to comment Share on other sites More sharing options...
Mrker60 Posted March 5, 2020 Author Share Posted March 5, 2020 Cheers.did 5 mm recline the seat a lot. What spacers did you use ? Thanks mate Link to comment Share on other sites More sharing options...
Daveb99 Posted March 5, 2020 Share Posted March 5, 2020 14 hours ago, Mrker60 said: Cheers.did 5 mm recline the seat a lot. What spacers did you use ? Thanks mate No, hardly at all, I just used them to add a bit of height at the front so the runners clear the carpets. They were just M8 ally spacers. I think it’s already quite a reclined seat angle as standard, are you sure you really need to change it? Link to comment Share on other sites More sharing options...
Mrker60 Posted March 5, 2020 Author Share Posted March 5, 2020 Yes .if i sit in a good position for the clutch. My arms are like i'm hugging a barrel. I'v put spacers in today loads better wish seat reclined though Link to comment Share on other sites More sharing options...
