hotpurple Posted November 9, 2019 Share Posted November 9, 2019 As per the title, does anyone know where I can get a replacement? Apparently Lotus don’t consider it to be a serviceable item and don’t stock spares. The car is an early S2 with the long tail roof. The roof still works, it just doesn’t pull right anymore. Link to comment Share on other sites More sharing options...
The Cakes Posted November 10, 2019 Share Posted November 10, 2019 From memory I think the VX220 part is cheaper (exactly the same). Google is your friend. Link to comment Share on other sites More sharing options...
Martin 111S Posted November 10, 2019 Share Posted November 10, 2019 1 hour ago, The Cakes said: From memory I think the VX220 part is cheaper (exactly the same). Google is your friend. Its not the same, thicker cable and less likely to snap. Crafty Plates is the co. that sells them - on ebay too Lotus do stock them, but often on back order Had both mine go on the cup within the first 18 months, which really is rubbish !! Luckily the dealer replaced under warranty, @ £100 + each isn't a joke tbh. Crafty Plates ones are around £50 Link to comment Share on other sites More sharing options...
The Cakes Posted November 10, 2019 Share Posted November 10, 2019 1 hour ago, Martin 111S said: Its not the same, thicker cable and less likely to snap. Crafty Plates is the co. that sells them - on ebay too Lotus do stock them, but often on back order Had both mine go on the cup within the first 18 months, which really is rubbish !! Luckily the dealer replaced under warranty, @ £100 + each isn't a joke tbh. Crafty Plates ones are around £50 I meant as in it will fit. Link to comment Share on other sites More sharing options...
Broadside Posted November 10, 2019 Share Posted November 10, 2019 Isn't the rear cable on the long tail longer? The ones crafty plates advertises on ebay are the front ones I believe (although I think he can make up what you want) Coincidentaly my front cable broke on Friday while traveling back from Bakewell and it was hammering it down!! I had to try and lash it up with duct tape to stop it acting like a parachute! I'm in the process of making a repair on mine by making a slightly different end piece at one end and using a length of new cable, cos I'm too tight to pay 50 quid 😂 Link to comment Share on other sites More sharing options...
hotpurple Posted November 11, 2019 Author Share Posted November 11, 2019 Thanks all. I had considered using a bike brake cable, as it looks like that’s what they’re made of originally. I just need to work out how to get it to clamp in to the end now. Link to comment Share on other sites More sharing options...
The Cakes Posted November 11, 2019 Share Posted November 11, 2019 Sorry didn't see the long tail bit 🙈 Link to comment Share on other sites More sharing options...
hotpurple Posted November 11, 2019 Author Share Posted November 11, 2019 Ah yes, the long tail does make a difference. I need to find a way to feed the cable through the roof material. It’s in a sheath like a bike brake cable but the ends are not removable, from what I can see. I need to take a better look at it in good light. I have a feeling they are stitched in there. Link to comment Share on other sites More sharing options...
Martin 111S Posted November 12, 2019 Share Posted November 12, 2019 On 11/11/2019 at 09:38, The Cakes said: Sorry didn't see the long tail bit 🙈 Snap, neither did I. Sorry for any misleading information. Link to comment Share on other sites More sharing options...
Broadside Posted November 12, 2019 Share Posted November 12, 2019 23 hours ago, hotpurple said: Ah yes, the long tail does make a difference. I need to find a way to feed the cable through the roof material. It’s in a sheath like a bike brake cable but the ends are not removable, from what I can see. I need to take a better look at it in good light. I have a feeling they are stitched in there. I think you have to peel back the fabric at the ends (I'm sure there's a write up on Seloc) On the front cable one end is either crimped or soldered in and the other floating with a nipple. I have made a new end with 2 small M3 grub screws (like a solderless nipple) to crimp the cable in position, if this works ok it will be easy to slip a new cable in if it happens again. I imagine you could do the same on the rear if you can be bothered with the faff, I just like to prove I can do it! 🙂 Link to comment Share on other sites More sharing options...
