crinkle Posted August 12, 2019 Share Posted August 12, 2019 Hello , Does anyone know where the aircon charging valve is on an Elise S2 ? Regards Crinkle. Link to comment Share on other sites More sharing options...
Martin R Posted August 12, 2019 Share Posted August 12, 2019 Nicked from elsewhere The system is charged with 0.55 kg of refrigerant HFC R134a. Filling points on Elise are located in the front services compartment, and on the Exige ahead of the RH rear wheel, accessible after removal of the front most part of the wheel-arch liner. (This depends on the year!) Standard R134a 'quick fit' connectors are used in the compressor suction & discharge pipes at the right side closest to the firewall of the engine bay; the low pressure vapour line is fitted in the pipe between the evaporator & compressor. the high pressure liquid line is fitted in the pipe between the compressor & condenser. There is a "Lotus Service Notes," "Section PL," that goes into great detail including torque setting for all the pipe work, diagrams, part numbers. All of the pipes are aluminium, they have a lip on each end, this makes the nuts captive. There are "O" rings these should be replaced if the joint is opened, not all the "O" rings are the same size. HTH Link to comment Share on other sites More sharing options...
crinkle Posted August 12, 2019 Author Share Posted August 12, 2019 Great stuff . Many thanks . Crinkle. Link to comment Share on other sites More sharing options...
