Justin C Posted July 18, 2019 Share Posted July 18, 2019 I have a stock S2 Exige S (220bhp) and am interested in changing the supercharger pulley for a bit extra power /torque. I have a done a search but can't find any threads about it. Does anyone have any experience /knoweldge to share on this. Elise shop sell 77mm which they say is good for a stock car, but is it realiable? Can it just be swapped over without any other mods or does it require re-tuning engine map etc. Is it worth it? Link to comment Share on other sites More sharing options...
kieranexige Posted July 18, 2019 Share Posted July 18, 2019 6 hours ago, Justin C said: I have a stock S2 Exige S (220bhp) and am interested in changing the supercharger pulley for a bit extra power /torque. I have a done a search but can't find any threads about it. Does anyone have any experience /knoweldge to share on this. Elise shop sell 77mm which they say is good for a stock car, but is it realiable? Can it just be swapped over without any other mods or does it require re-tuning engine map etc. Is it worth it? Grey area. Some say the ecu will learn the parameter's but some I've read say its not enough. Also remember a smaller pulley spins the charger faster , thus intern heating the air more so cooling becomes key not to get heat soak. If it was me I'd be buying a cheap 240 ecu and a set of injectors. The easiest and simplest way for cheap power without needing the fuel pump for a 260. Also worth adding a trd airbox and a bigger intercooler at a later date , made a difference to my bum dyno Link to comment Share on other sites More sharing options...
Justin C Posted July 19, 2019 Author Share Posted July 19, 2019 16 hours ago, kieranexige said: Grey area. Some say the ecu will learn the parameter's but some I've read say its not enough. Also remember a smaller pulley spins the charger faster , thus intern heating the air more so cooling becomes key not to get heat soak. If it was me I'd be buying a cheap 240 ecu and a set of injectors. The easiest and simplest way for cheap power without needing the fuel pump for a 260. Also worth adding a trd airbox and a bigger intercooler at a later date , made a difference to my bum dyno Thanks for that. I thought it sounded too easy to be true. I think I'll stay with stock. Link to comment Share on other sites More sharing options...
kieranexige Posted July 19, 2019 Share Posted July 19, 2019 You can buy a 240 ecu for circa 250 on exiges / seloc , plus a set of injectors , cheap and easy mod for 20hp. Link to comment Share on other sites More sharing options...
