Rick Fry Posted June 5, 2019 Share Posted June 5, 2019 Hi sorry if this has been coverered before. I have an S1 elise that wont start. I have fuel and compression but no spark. Changed the coil pack, distributer cap, rotar arm. I dont appear to be getting 12v to the coil but dont have a wiring diagram so finding it quite a challenge. Does anyone have a wiring diagram or any suggestions as to what this could be. Thanks in advance Link to comment Share on other sites More sharing options...
Broadside Posted June 6, 2019 Share Posted June 6, 2019 Hi, have you checked the basics, battery condition, earths (g.box to chassis) and fuses? are other electrical functions ok? I'm sure I downloaded a manual, if you cant find a wiring diagram I'll try and find where I saved it 🙂 Link to comment Share on other sites More sharing options...
Lithopsian Posted June 7, 2019 Share Posted June 7, 2019 12V to the coil should come from the main relay, in the MFRU. Then the ECU gives it a path to earth. So the MFRU is the big suspect. The coil comes from big plug pin 8, brown and pink wire. Note that there are two pins with brown and pink wires, and they're connected to each other internally. If there is no power there, then look for the relay input on pin 6, brown wire, which comes from the maxi fuse. Link to comment Share on other sites More sharing options...
