nickashton Posted April 24, 2019 Share Posted April 24, 2019 I am due to change all tyres shortly and I have come across ADVAN AD07 cheaper than AD07 LTS2. Has anyone run AD07 instead of AD07LTS? There is conflicting info out there. HELP!! Link to comment Share on other sites More sharing options...
Steve J Posted April 24, 2019 Share Posted April 24, 2019 Hasn't everyone been running AD08 for years now since it replaced the 07? Link to comment Share on other sites More sharing options...
Broadside Posted April 25, 2019 Share Posted April 25, 2019 Just put AD08's on mine, all seems good 👍 Link to comment Share on other sites More sharing options...
nickashton Posted April 25, 2019 Author Share Posted April 25, 2019 The fronts are 175. What size Ad08,s did you put on the front? Link to comment Share on other sites More sharing options...
Steve J Posted April 26, 2019 Share Posted April 26, 2019 What elise do you have? Assume you have 5.5 x 16 front wheels and currently have 175 x 55 x 16 AD07 tyres. Please correct if assumed wrong. You should easily be able to fit 185 x 50 x 16 Link to comment Share on other sites More sharing options...
Broadside Posted April 26, 2019 Share Posted April 26, 2019 I fitted 205 fronts but have 7" rims, not sure about availability on narrower options Link to comment Share on other sites More sharing options...
nickashton Posted April 27, 2019 Author Share Posted April 27, 2019 19 hours ago, Steve J said: What elise do you have? Assume you have 5.5 x 16 front wheels and currently have 175 x 55 x 16 AD07 tyres. Please correct if assumed wrong. You should easily be able to fit 185 x 50 x 16 I have an early S2 currently with potenza all round. Am I right in thinking that the AD08 / AD08R aren't LTS. Would that affect anything? If not would go for the AD08 185 on the front. The more I research tyres the more it becomes a minefield!! Link to comment Share on other sites More sharing options...
Martin 111S Posted April 27, 2019 Share Posted April 27, 2019 54 minutes ago, nickashton said: I have an early S2 currently with potenza all round. Am I right in thinking that the AD08 / AD08R aren't LTS. Would that affect anything? If not would go for the AD08 185 on the front. The more I research tyres the more it becomes a minefield!! You're correct, the AD08/08R's aren't LTS - but won't make that much difference tbh, if any. I've run 08's for years and since Lotus now put A052's on I doubt they are LTS, and certainly the Ad08R's they put on the 260 Cup weren't LTS2 compound is very similar to AD08R Currently running AD08R's on the 250 Cup for fast road, and they're fine. Link to comment Share on other sites More sharing options...
Steve J Posted April 27, 2019 Share Posted April 27, 2019 I've run both lotus and non-lotus versions of the various tyres over the years. Even with track use I never found a difference. 185 on the fronts of your S2 will make a nice difference to the inherent understeer especially if you've had the geo changed too. Link to comment Share on other sites More sharing options...
Steve J Posted April 28, 2019 Share Posted April 28, 2019 Cheap fronts. https://classifieds.seloc.org/ads/ad07-lts-front-tyres/ Link to comment Share on other sites More sharing options...
nickashton Posted April 28, 2019 Author Share Posted April 28, 2019 Thanks Steve. I am now thinking AD08 all round. The only problem is I cannot find 185 AD08 for the front. Anyone out there been able to source them or does it fall for a combination of AD07 for the front and AD08 for the rear? Just not sure on mixing tyres? Thanks Link to comment Share on other sites More sharing options...
Steve J Posted April 29, 2019 Share Posted April 29, 2019 Quick check on Blackcircles and Mytyres say they have them in stock. Link to comment Share on other sites More sharing options...
nickashton Posted April 29, 2019 Author Share Posted April 29, 2019 I can’t find AD08 in 185 x 50 x 16 anywhere. Other than AD07 LTS are there any other suitable tyres with the 185 x 50 x 16 size.? Link to comment Share on other sites More sharing options...
Steve J Posted April 29, 2019 Share Posted April 29, 2019 Hmm. Looks like AD08R is 205 for the 16 inch wheel. Don't know why it came up 185 on my phone. 205 will be too wide for your 5.5 fronts I would have thought. There is stock of the AD07 still so maybe that'll be your better choice. Skinny front wheels on the early S2 were a right pain for tyre availability from my recollection. Link to comment Share on other sites More sharing options...
