SMP Posted March 27, 2019 Share Posted March 27, 2019 Just a heads up for anyone with an S2 having central door locking issues - appears it’s a fairly common issue. Mine packed up a couple of weeks or so ago, and after a little digging I came across this page on SELOC - https://wiki.seloc.org/a/Central_Locking_Module_Replacement However, getting my sticky little paws on a replacement CDL module is not as easy / cheap as I’d hoped. I then came across this page - https://www.ebay.co.uk/itm/Lotus-Elise-S2-Switch-Pack-Module-Repair-Service-/163541462818 For £40 including registered post return and a turnaround of less than 4 days including a weekend I can only recommend using Paul’s services. That was for a UK car, but he does post overseas also. No link other than a very satisfied customer - well recommended 👍🤘 The instructions are right though - it’s a sod to remove / refit 😂 Link to comment Share on other sites More sharing options...
Simon Brough Posted March 27, 2019 Share Posted March 27, 2019 I've had to use my key in the door lock to operate the locks for 18mths now on my 05' S2 ! Will this fix the issue ? Thanks in advance Simon. Link to comment Share on other sites More sharing options...
SMP Posted March 28, 2019 Author Share Posted March 28, 2019 Hi Simon, Very likely - it's usually one or both relays on the circuit board that fail and this is what gets replaced by default. I think the only part that can't be replaced is the actual microprocessor but that's apparently a very rare failure. Si. Link to comment Share on other sites More sharing options...
R5K Posted March 28, 2019 Share Posted March 28, 2019 If you can solder the relays are really cheap. I did my fog lights which I believe is the same relay. I posted some pictures when I did it Rich Link to comment Share on other sites More sharing options...
