Broadside Posted January 4, 2019 Share Posted January 4, 2019 1 hour ago, MrWill said: @Broadside... Mines got four threads riveted into the footrest and bolted through the floor pan. ... Velcro would be easier😋 Thank you, I might fabricate a prototype, certainly velcro will enable me to position to suit first. Its not top of my list at the moment though! Link to comment Share on other sites More sharing options...
Martin R Posted January 4, 2019 Author Share Posted January 4, 2019 20 minutes ago, Broadside said: Thank you, I might fabricate a prototype, certainly velcro will enable me to position to suit first. Its not top of my list at the moment though! Mines held in with Velcro. They used either that or the screws through the floor pan. Typical Lotus. Link to comment Share on other sites More sharing options...
kieranexige Posted January 5, 2019 Share Posted January 5, 2019 Velcro here too Link to comment Share on other sites More sharing options...
MrWill Posted January 5, 2019 Share Posted January 5, 2019 Stick with the Velcro. I found quite bad corrosion on the floor pan where it had chemically reacted with the washers. Cleaned, treated and covered with duralac. Refitting with plastic washers Front rebuild finished! Link to comment Share on other sites More sharing options...
Broadside Posted January 5, 2019 Share Posted January 5, 2019 Velcro it will be!! Link to comment Share on other sites More sharing options...
smithpaulg Posted January 6, 2019 Share Posted January 6, 2019 Difficult to see in these shots but this weekend i installed some running boards. Had them from a chap on seloc who sells them. Sprayed them up during the week, then drilled the holes in underside to mount them (that wasnt nerveracking - but quite simple in the end). Really please with the look and compliments the front splitter and balances the car. Also took the opportunity to tidy up the rust that was developing on the brake-disc centres. Link to comment Share on other sites More sharing options...
DeanB Posted January 6, 2019 Share Posted January 6, 2019 Looking good Paul Link to comment Share on other sites More sharing options...
Broadside Posted January 6, 2019 Share Posted January 6, 2019 On 05/01/2019 at 19:10, MrWill said: Stick with the Velcro. I found quite bad corrosion on the floor pan where it had chemically reacted with the washers. Cleaned, treated and covered with duralac. Refitting with plastic washers Front rebuild finished! nice alloy bells 😊 Link to comment Share on other sites More sharing options...
MrWill Posted January 7, 2019 Share Posted January 7, 2019 21 hours ago, Broadside said: nice alloy bells That's what all the boys say. 😆 Link to comment Share on other sites More sharing options...
Broadside Posted January 7, 2019 Share Posted January 7, 2019 I've got a nasty feeling that I've talked myself into buying a set of Nitrons, just because I've got a rusty spring............. Link to comment Share on other sites More sharing options...
Martin R Posted January 8, 2019 Author Share Posted January 8, 2019 4 hours ago, Broadside said: I've got a nasty feeling that I've talked myself into buying a set of Nitrons, just because I've got a rusty spring............. Good idea. Just make sure you dont go to hard on the spring ratings? If its 90% road use stay fairly soft would be my advice. Link to comment Share on other sites More sharing options...
Broadside Posted January 8, 2019 Share Posted January 8, 2019 16 hours ago, Martin R said: Good idea. Just make sure you dont go to hard on the spring ratings? If its 90% road use stay fairly soft would be my advice. Yes, I agree with you about spring rates. I guess my existing dampers are pretty old so buying new springs for them is probably not the wisest long term investment. Link to comment Share on other sites More sharing options...
Martin R Posted January 16, 2019 Author Share Posted January 16, 2019 Oil leaks done thanks to Gav. he is glad to see the back of it lol. Just a couple of small jobs to do and im ready to rumble Link to comment Share on other sites More sharing options...
jody391 Posted January 16, 2019 Share Posted January 16, 2019 Cadwell 25th feb? Link to comment Share on other sites More sharing options...
@ndy Posted January 16, 2019 Share Posted January 16, 2019 Reading all this makes me envious..... I miss working on / upgrading my S1 and don't want to start down that slippery slope with the current Elise yet ! Link to comment Share on other sites More sharing options...
