Daveb99
Epoxy Garage Floor Paint
I've previously used inexpensive ordinary garage floor paint from the likes of screwfix, but it peels over time, so it’s time for the decent stuff...
I’m looking to use Epoxy resin paint (the 2 pack stuff), can anyone recommend a supplier and also any tips on the process - best to prime first? I know it is applied using a large roller, and it’s advisable to mix a smaller tin first to do the cutting in around the edges, but that’s about all I know...
Share this post
Link to post
Be careful as garage floor paint becomes like an ice rink when wet.
Share this post
Link to post
Dave I acid etched mine first to give it a key.
As above it is slippy when wet, and do it on a hot day where you can leave to door open. It stinks and if you have a internal garage it whiffs abit through the house...
Don't ask me how I know
Share this post
Link to post
I did Johnson's 2-part epoxy, 9years ago and it's still good. Fumes were not too bad.   The concrete pad had a good top surface / was pretty new so no need to etch.
I also did the bottom row of bricks the same colour, so no need for cutting-in.
Share this post
Link to post
Mind you in thinking about it..  About 3 months after I did it we had a office refurb and I ended up putting 2 layers of new carpet tiles on top of it.
Share this post
Link to post
Dave, have you considered plastic interlocking floor tiles. We were fitting out a car dealership and had some left over, so I used them in my garage. They’re easy to lay and really robust once they’re down, plus I find them a bit warmer if im kneeling or sitting on the garage floor in the colder months. A friend of mine has just gone over his floor paint with some because he was fed up of having to re coat it.
Share this post
Link to post
I went for interlocking tiles too, and as Adam says, I'm expecting some insulation properties this winter. You'll have to excuse the mess, we're DIY'ing at the moment...
Share this post
Link to post
I agree. The interlocking floor tiles would be my choice if you don't like bare concrete.
Share this post
Link to post
Thanks everyone for all the advice.  I like the sound of the interlocking tiles, can anyone recommend a supplier - where did you get them from Kurt / Adam?
Share this post
Link to post
I don’t recall the manufacturer of mine. Luckily for me they didn’t cost me anything.... We were refurbishing a car dealership and they had specified this particular tile. We were half way through laying them and they had a change of management at the dealership and the new chap decided he would like ceramics, so I ended up with enough to do a couple of garages.
I did however organise some for a colleague a couple of months ago. I used a flooring supplier in leicester called Garrad Waters. They were able to supply two or three different types.  I’ll see if I still have the information.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
