Chraser Posted August 6, 2018 Share Posted August 6, 2018 Hello, Does anyone know if the Gearbox in a Lotus Elise S2 (01), K series is mounted in other Rover cars? I might need a new gearbox and that is the reason to the question. Problem with the reverse gear…. Thanks in advance! Link to comment Share on other sites More sharing options...
@ndy Posted August 6, 2018 Share Posted August 6, 2018 They were fitted to both the Elise S1 & S2 running the K series engine, they were also used in the MGF and MG ZR so you shouldn't have a problem picking up a replacement but just make sure you get the right ratio. Lots of good info here - https://wiki.seloc.org/a/Rover_PG1_gearbox Andy Link to comment Share on other sites More sharing options...
Steve J Posted August 6, 2018 Share Posted August 6, 2018 S2 is close ratio except for the 111s. S1 is the other way round. So you'll need a close ratio one. B4BP Link to comment Share on other sites More sharing options...
Chraser Posted August 6, 2018 Author Share Posted August 6, 2018 @@ndy @Steve J, Many thanks for your answers! Link to comment Share on other sites More sharing options...
Martin R Posted August 6, 2018 Share Posted August 6, 2018 Trouble with reverse may well be a linkage issue? Link to comment Share on other sites More sharing options...
Chraser Posted August 7, 2018 Author Share Posted August 7, 2018 Hello Martin, Many thanks for your reply as well. The previous owner upgraded the gear linkage, quick shifter and new gear cables back in 2016. I will consider looking into this! Kind regards Mattias Link to comment Share on other sites More sharing options...
Martin R Posted August 7, 2018 Share Posted August 7, 2018 Check the clips are still in place that hold the cables near the linkage. Link to comment Share on other sites More sharing options...
Steve J Posted August 7, 2018 Share Posted August 7, 2018 Similar issue here. Some good pictures of what you need to look at too. https://forums.seloc.org/viewthread.php?tid=452063&page=1#pid7851874 Link to comment Share on other sites More sharing options...
MrWill Posted August 7, 2018 Share Posted August 7, 2018 Hi. All of the above i.e check the clips on the "abutment" near the linkage but also there is a limit screw at the front of the gear stick housing which needs to be set correctly. The c clip under the gear lever can also foul on the left cable if its fitted incorrectly. A bit of tinkering may well save you the cost of a gearbox so worth it if you're that way inclined. And if it is a limit srew or some other part on the linkage is out or catching, a new box isnt going to work either so worth eliminating first. Cheers Link to comment Share on other sites More sharing options...
Chraser Posted August 8, 2018 Author Share Posted August 8, 2018 Hi, Many thanks for sharing your ideas! Kind regards Mattias Link to comment Share on other sites More sharing options...
Chraser Posted August 9, 2018 Author Share Posted August 9, 2018 Guys, It seems that the problem was solved after some tuning of the gear linkage. Thanks again for the advices! Cheers Link to comment Share on other sites More sharing options...
Steve J Posted August 10, 2018 Share Posted August 10, 2018 Result Link to comment Share on other sites More sharing options...
Chraser Posted August 12, 2018 Author Share Posted August 12, 2018 Steve, Still working Kind regards Link to comment Share on other sites More sharing options...
