Daveb99 Posted May 30, 2018 Share Posted May 30, 2018 My 2013 Exige V6 S Roadster will be due a service soon. I currently don't have any oil for top ups, so thought I'd buy in bulk and supply the oil to the dealer for the next few services, leaving me with plenty for topping up as needed, and saving a fair bit of dosh in the process. ECP on eBay are currently doing Castrol Edge 32L (8x 4 Litres) SAE 5W40 Fully Synthetic Titanium FST for £228.46 with the current 20% off promo. That's just £7.14 per litre! Is there any reason why I shouldn't jump on this deal? I presume it would be fine in the engine as it meets the ACEA A3/B3 spec? Fast road use only for the foreseeable future... Link to comment Share on other sites More sharing options...
IAN G Posted May 30, 2018 Share Posted May 30, 2018 opie oils have 20% off castrol atm i personally prefere fuches titan pro s Link to comment Share on other sites More sharing options...
oilman Posted May 31, 2018 Share Posted May 31, 2018 Hi We're cheaper than ECP, £216 for 8x4L of the Edge 5w-40, just use the code SELOC to get 10% off the website price (the 20% discount is only on the Edge 5w-30). If you want a proper performance oil, the Fuchs Pro S and Millers CFS are £46.99 per 5L, but if you were going for 6 cans, using the code MSPORT15, that will come to £239.65. Cheers Tim Link to comment Share on other sites More sharing options...
matthewhaskins Posted May 31, 2018 Share Posted May 31, 2018 I'd speak with your dealer before making a purchase as our dealer insurance is quite stringent about using parts that we have not supplied. Our price for oil during an oil service also includes the cost to dispose of your old oil, you may have to factor this into your calculations as well. Finally, the recommendation from Lotus Cars was 5W40 for normal applications and 10W60 for track use up to the point where they started to use Petronas oils then they changed the recommended oil to 0W40 for track use. Link to comment Share on other sites More sharing options...
IAN G Posted May 31, 2018 Share Posted May 31, 2018 so what oil , brand and type do lotus now recommend ? the one in my hand book is no longer availiable Link to comment Share on other sites More sharing options...
MrWill Posted May 31, 2018 Share Posted May 31, 2018 If you feed the lotus fuchs or millers as per opie oils advice your car will be very happy. Manual should have viscosity range? The rover for example says anything in the range of 10 and 60. 10-40 normal motoring. Brisk weekend blat. All perfectly fine 10-50 spirited driving and perfectly fine for normal track days. 10-60 hardcore trackdays races sprints etc The higher Oil pressure modern engines run makes a zero or 5 rating less of an imperative IMO. Link to comment Share on other sites More sharing options...
