GreyKnight Posted May 15, 2018 Share Posted May 15, 2018 Hi folks It's been a fair while since I last posted on MLOC, I've been around since 2005 and was very active here in the late 2000's, but then what with buying my first home, getting married, having a kid, moving house again, changing jobs etc etc my S1 Elise just got less use and more old. Eventually a couple of years ago I took it off the road and decided to give it some TLC in readiness for spending some quality time with it again along with my now 5 year old boy. So, it's been sat on my drive up on axle stands all this time while I have slowly taken the important parts to bits and sorted them all out. I'm finally at the stage where the front clam can go back on, the undertrays can be re-fitted, the wheels can go on and get new tyres and it will go back on the road! Things I've done include:- Full C service Front clam off New radiator fitted Heater box re-built and new heater matrix fitted All suspension removed and blasted, zinc passivated, painted and reassembled with stainless fixings New ball joints, bushes, drop links, TRE's etc fitted New Nitron SS dampers New steering arm gators New discs and pads fitted New fixings for the front clam fitted Driving light and headlight brackets taken off, stripped and painted New headlights fitted Once the car is fully back together I'll be loading it onto a trailer and taking it for a full geo somewhere and a check by a pro to make sure I haven't put things on backwards. Then Once that's done it's going for a full respray at my brother's garage and then (eventually) it'll get an interior re-trim when my wallet has recovered. Anyway, the point is that I intend to come along to a few events and gatherings this summer if all goes to plan. Hope to see some familiar faces as well as new ones! cheers Graham Link to comment Share on other sites More sharing options...
Mark H Posted May 15, 2018 Share Posted May 15, 2018 Hi, welcome back Link to comment Share on other sites More sharing options...
Elisemadray Posted May 16, 2018 Share Posted May 16, 2018 Cant wait to see it once its had its respray it should be stunning Hope you can make 'Lotus in the Peak' July 15th Cheers Ray Link to comment Share on other sites More sharing options...
DeanB Posted May 16, 2018 Share Posted May 16, 2018 Welcome back Graham! The work you've done sounds great. I wish I had the patience but I'm useless with the spanners Link to comment Share on other sites More sharing options...
Phil S1 Posted May 16, 2018 Share Posted May 16, 2018 Welcome back Graham, the transformation brought about by replacing the ball joints and bushes should be a revelation I'm sure, it was for me when I replaced all mine on my old 49. Link to comment Share on other sites More sharing options...
MrWill Posted May 16, 2018 Share Posted May 16, 2018 Welcome back! Can't beat that ' done it yourself' satisfaction. Link to comment Share on other sites More sharing options...
MilesH Posted May 16, 2018 Share Posted May 16, 2018 Good to see you back Graham. I remember your post over on seloc when you had the rear bracket issue, I did feel for you at that point! Glad it's all coming together now. Link to comment Share on other sites More sharing options...
