Jonathan E Posted April 16, 2018 Share Posted April 16, 2018 My Elise has refused to start on a couple of occasions recently. Turn key and “click”, turn off leave a few moments then it starts as it should. I suspect the starter motor is on its way out?, but will also check the battery. I’ve already checked all connections and they are fine. I presume the starter in an S2 111s is a standard Rover part so where is best to buy from Tia Link to comment Share on other sites More sharing options...
Dr H Posted April 16, 2018 Share Posted April 16, 2018 Before you do anything else, check the battery. If you have another car connect it up and try to jump start it. If it's still the same 'click' then could well be the starter. When you say 'on a couple of occasions' - has it started OK in between these occasions? Has it sat for a period between the two? Link to comment Share on other sites More sharing options...
Lisa Newman Posted April 16, 2018 Share Posted April 16, 2018 I agree sounds like you need a new battery, mine still does this if it’s been left for a couple of weeks , buy a trickle charger too, this helps your battery to have a boost, they’re Brilliant!Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Jonathan E Posted April 16, 2018 Author Share Posted April 16, 2018 It did it a couple of times last year, and hs dine it twice this year so far including this morning, gave it a good run out on Saturday. It starts fine most of the time and is always on a battery conditioner when not being used Link to comment Share on other sites More sharing options...
Elisemadray Posted April 16, 2018 Share Posted April 16, 2018 3 hours ago, Jonathan E said: It did it a couple of times last year, and hs dine it twice this year so far including this morning, gave it a good run out on Saturday. It starts fine most of the time and is always on a battery conditioner when not being used could still be the battery beginning to fail similar thing happened to mine, I tried 6 inch nail technology n hit with a hammer not really, I changed the battery all was good, but you could still be right about the starter motor Not much help am I Link to comment Share on other sites More sharing options...
Jonathan E Posted April 17, 2018 Author Share Posted April 17, 2018 It all helps Ill get the battery checked it’s on the original so could with changing anyway Link to comment Share on other sites More sharing options...
Martin R Posted April 17, 2018 Share Posted April 17, 2018 Sounds like the battery is right on the cusp of having enough power to turn the starter. Rare to have a starter motor problem on a K. Link to comment Share on other sites More sharing options...
Jonathan E Posted April 17, 2018 Author Share Posted April 17, 2018 Thanks Martin, I’ll take a closer look at the battery when I have time. Any recommendations regarding which battery to go for? Link to comment Share on other sites More sharing options...
Dr H Posted April 17, 2018 Share Posted April 17, 2018 If you want to use a standard size one I'd go for a good quality 063 size. I bought a Bosch Silver form Halfords, but they don't seem to sell them anymore. Maybe this http://www.halfords.com/motoring/bulbs-blades-batteries/car-batteries/yuasa-5-year-guarantee-hsb063-silver-12v-car-battery Good thing about Halfords is the 5 year warranty (just keep the receipt). Or Carparts4less (Eurocarparts) https://www.carparts4less.co.uk/cp4l/c/Lotus_Elise_1.8_2004/p/car-parts/electrical/car-electrics-and-car-lighting/car-battery/?444770638&1&04de2175c630000bd261be3279491f6f98192397&000020 £81 with current 12% discount code (April12) and free delivery. Link to comment Share on other sites More sharing options...
Jonathan E Posted April 17, 2018 Author Share Posted April 17, 2018 Thanks Leigh, its a Bosch thats on there now. Had a quick voltage check just now, Battery cold is reading 12.6v, drops to 10.61v on start up then settles at 14.3v when the engine is running. I left the conditioner off last night and on first turn I got the "click". turned off the ignition and tried again and the car started Does this point towards the battery being knackered? Link to comment Share on other sites More sharing options...
Dr H Posted April 17, 2018 Share Posted April 17, 2018 That drop sounds normal I would say. Maybe others can comment. Link to comment Share on other sites More sharing options...
Jonathan E Posted April 17, 2018 Author Share Posted April 17, 2018 Does seem about right according to the internet Im taking it up North at the weekend and don't really want any issues. Might chuck a new battery on and see how it goes. Link to comment Share on other sites More sharing options...
Dr H Posted April 17, 2018 Share Posted April 17, 2018 As the voltage drop at start looks OK then it could well be your starter. Link to comment Share on other sites More sharing options...
Jonathan E Posted April 17, 2018 Author Share Posted April 17, 2018 £145 from Eliseparts, are the starters boggo standard and available all over the net or are they Lotus specific? As much as I like Eliseparts £145 seems a bit steep unless it is Lotus specific Link to comment Share on other sites More sharing options...
Martin R Posted April 17, 2018 Share Posted April 17, 2018 Jon, i may well have my old one in the loft. I changed it as a preventative measure when i had the engine rebuilt. Nothing wrong with it as such. You are welcome to try it to diagnose yours? The other thing is try the same test at the starter motor terminals? Should be about the same reading give or take a small amount for volt drop. If its significantly different it would suggest a bad connection on live or also dont forget the ground to the engine block? Link to comment Share on other sites More sharing options...
