StokieAfro Posted June 11, 2017 Share Posted June 11, 2017 Ok cool, Thank you. Thinking I may actually get my backside to LITP this year for a nosey. I have had my car 5 year's now and been a member here for the duration and not made it once yet. Link to comment Share on other sites More sharing options...
Jonathan E Posted June 11, 2017 Share Posted June 11, 2017 Come on down, it's great day out, I'll be there so will nick so you can have a proper look. Link to comment Share on other sites More sharing options...
nickashton Posted June 12, 2017 Author Share Posted June 12, 2017 Link to comment Share on other sites More sharing options...
MrCoola Posted November 7, 2017 Share Posted November 7, 2017 Just wondering if any one with an Elise without an external aerial has fitted a DAB, I was looking to go for the internal window one but was wondering how I ground it as I presume the A pillars are Aluminium. Link to comment Share on other sites More sharing options...
Daveb99 Posted November 7, 2017 Share Posted November 7, 2017 I fitted a windscreen DAB aerial in my S1, and the same thing is fitted in the V6 I have now. From memory I ran a second ground wire from the aerial down to somewhere under the dash.I've had superb reception with both - and I can see there's a second cable coming down from the windscreen aerial in the V6 too so I presume the installer went a similar route. Highly recommended.. Link to comment Share on other sites More sharing options...
winthattt Posted November 9, 2017 Share Posted November 9, 2017 I have a totally different solution. I have installed a BT receiver (Alpine) and use my phone to get the radio, same as my music feed from Spotify and others. I have a DAB system and aerial but the phone over the internet works much better. Link to comment Share on other sites More sharing options...
Daveb99 Posted November 11, 2017 Share Posted November 11, 2017 On 09/11/2017 at 21:38, winthattt said: I have a totally different solution. I have installed a BT receiver (Alpine) and use my phone to get the radio, same as my music feed from Spotify and others. I have a DAB system and aerial but the phone over the internet works much better. That's certainly another way - but what happens when your mobile data signal drops out in areas with no coverage? Link to comment Share on other sites More sharing options...
winthattt Posted November 11, 2017 Share Posted November 11, 2017 1 hour ago, Daveb99 said: That's certainly another way - but what happens when your mobile data signal drops out in areas with no coverage? It's more reliable than my Dab or Fm reception, which says something for how bad they are. When it drops it it is just a pause/gap in the programme. Mobile data coverage is not too bad. For music from a streaming service it caches ahead so drop outs can be handled. Link to comment Share on other sites More sharing options...
nickashton Posted November 12, 2017 Author Share Posted November 12, 2017 The dabonwheels aeriel fitted to my car works perfectly well. Well worth doing for less than sixty quid! Worth mentioning I have a Sony DAB radio which works well. More than happy for anyone to come over to Congleton to look at the install. Nick Link to comment Share on other sites More sharing options...
Jonathan E Posted November 13, 2017 Share Posted November 13, 2017 I would have been happy with the stick on job but just couldn't get it to work very well. I struggle to get a mobile phone signal here let alone 3/4G for streaming so that was a non starter, although downloaded playlists on Spotify stream happily enough. The fact I can pick up most dab stations even when I'm out in the middle of Wales is testament to the quality of the DAB on wheels offering. Having said all that I listen to music in the Elise less and less these days but its there if I need it, like being stuck for 4 hours on the M20 Link to comment Share on other sites More sharing options...
MrCoola Posted November 16, 2017 Share Posted November 16, 2017 I fitted a pioneer DAB in my S3 Elise which does not have an exterior aerial. So fitted a pioneer amplified internal window aerial and routed it behind the steering wheel to the drivers side of the windscreen. Works brilliantly. No need for earthing etc Link to comment Share on other sites More sharing options...
