Martin R Posted February 4, 2016 Share Posted February 4, 2016 If you are not doing track days AO48 are a waste of time. As Andy says get some AD08R. Link to comment Share on other sites More sharing options...
John FISH Curtis Posted February 4, 2016 Author Share Posted February 4, 2016 What is the difference between the AD08 & AD08R apart from price?..... https://www.tyreleader.co.uk/compare-car-tyres/?elem[]=276926&elem[]=423054 Link to comment Share on other sites More sharing options...
scatty Posted February 4, 2016 Share Posted February 4, 2016 I had ad08s on my previous exige, standard ride height and they were fine. No rubbing at all.... The ad08r is the newer model brought out last year I believe... The ad08 would be fine, it's just the previous model... Link to comment Share on other sites More sharing options...
John FISH Curtis Posted February 4, 2016 Author Share Posted February 4, 2016 Think I've got the fronts correctly....... https://www.tyreleader.co.uk/cart/?t%5B0%5D=tyre&i%5B0%5D=433834&mount=0&q%5B0%5D=2 Not a bad price for a full set. Link to comment Share on other sites More sharing options...
scatty Posted February 4, 2016 Share Posted February 4, 2016 You aren't going to mix ad08s with the 48' s are you??? Link to comment Share on other sites More sharing options...
John FISH Curtis Posted February 4, 2016 Author Share Posted February 4, 2016 No, get a full set of ADO8R's Full set (as above link) is £347.78. Fronts only available as 205/45 R16 if this is the size others have mentioned. Link to comment Share on other sites More sharing options...
jody391 Posted February 4, 2016 Share Posted February 4, 2016 I have the ado8 tyres on the s1 on my comps, at Donno thunder in the park in the wet and damp I couldn't get the feeling to push the car! I then swapped to the R888's and they were so much better! More feel front and rear and dare I say more forgiving. Link to comment Share on other sites More sharing options...
Martin R Posted February 4, 2016 Share Posted February 4, 2016 John did say no trackdays? IMO AD08r are perfect for just road use. The experience i have are they are stunning in the wet. I know which i would choose as a wet and dry road tyre. Edit, 205/50/16 on the front. 225/45/17 on the rear Link to comment Share on other sites More sharing options...
John FISH Curtis Posted February 4, 2016 Author Share Posted February 4, 2016 Fronts are only available as 205/45/16, not 205/50/16 No track use, just road..... and garage Link to comment Share on other sites More sharing options...
Martin R Posted February 4, 2016 Share Posted February 4, 2016 Fronts are only available as 205/45/16, not 205/50/16 No track use, just road..... and garage Whats this then? Scotch mist? http://www.camskill.co.uk/m62b2964s300p114345/Yokohama_Tyres_Car_Yokohama_AD08R_Advan_Neova_Yokohama_AD_08_R_-_205_50_R16_87V_TL_Fuel_Eff_%3A_F_Wet_Grip%3A_B_NoiseClass%3A_3_Noise%3A_75dB And on tyreleader https://www.tyreleader.co.uk/car-tyres-205-50-16/?m%5B8%5D=on Link to comment Share on other sites More sharing options...
Bryno Posted February 4, 2016 Share Posted February 4, 2016 Yes it's the 205/45/16 AD08R you want. I priced up same at all the usual suspects, Tyre leader cheapest and advantage of delivery to one of their recommended fitting places. Link to comment Share on other sites More sharing options...
Martin R Posted February 4, 2016 Share Posted February 4, 2016 Just had a search around. Some seem to use 50 front profile and some 45 front profile? Im sure mine are 50. The front will sit slightly lower with 45 profile. http://wiki.seloc.org/a/Tyres_for_OZ_Racing_Rims#Advan_A048 Might also cause a problem if you have ABS? The reference is with OZ racing rims? I dont know if this applies to all rims? Link to comment Share on other sites More sharing options...
lukevx Posted February 4, 2016 Share Posted February 4, 2016 Not sure if it's documented anywhere but the ad08r 'seem' to be a softer compound than the older ad08. No rubbing issues on mine with 205/45/16 Just had a search around. Some seem to use 50 front profile and some 45 front profile? Im sure mine are 50. The front will sit slightly lower with 45 profile. http://wiki.seloc.org/a/Tyres_for_OZ_Racing_Rims#Advan_A048 Might also cause a problem if you have ABS? The reference is with OZ racing rims? I dont know if this applies to all rims? Standard 195/50/16 is 601mm diameter 205/45/16 is 591mm 205/50/16 is 611mm Ride height is going to be 5mm lower or higher than standard depending on which you go for. I went for the 45s car is still on standard billies and I'd rather drop the front and run a little more rake than raise it. Link to comment Share on other sites More sharing options...
Martin R Posted February 4, 2016 Share Posted February 4, 2016 I suppose as long as you set the ride height with the tyres on it makes no difference? What front profile are AO48? as standard issue? surely 195 and 205, 50 profile have the same diameter and just the width is different? Just checked looks like 5mm difference in ride height, How strange? Link to comment Share on other sites More sharing options...
@ndy Posted February 5, 2016 Share Posted February 5, 2016 I suppose as long as you set the ride height with the tyres on it makes no difference? What front profile are AO48? as standard issue? surely 195 and 205, 50 profile have the same diameter and just the width is different? Just checked looks like 5mm difference in ride height, How strange? I went all through this and got to the same conclusion when I had the S2..... I ran 205/45/16 on the front with no issues, I recommend doing the same Fish. Link to comment Share on other sites More sharing options...
