P4N Lotus Posted August 9, 2014 Share Posted August 9, 2014 hi all what should the Evora tyre pressure be? the book says 33.5psi front and 36rear. should they be at this or higher or lower psi? what's the benefits to more or less air presure on high speeds, handling, wear and grip? Link to comment Share on other sites More sharing options...
G Posted August 9, 2014 Share Posted August 9, 2014 I am running mine at around 34R & 31F if I recall. They seem to be wearing evenly across the tyre. Link to comment Share on other sites More sharing options...
P4N Lotus Posted August 9, 2014 Author Share Posted August 9, 2014 reason I ask Stratstone put mine to 30psi on both front and rear. I asked them why and they mentioned that lotus personnel had suggested that that pressure gives better handling at higher speeds than what the manual gives. Any further comments or how this will affect the wear or anyone else heard this? Link to comment Share on other sites More sharing options...
P4N Lotus Posted August 12, 2014 Author Share Posted August 12, 2014 Having now driven at these pressures for the last three days, the grip and cornering is actually much better than what lotus have set. Works out at 30psi rear and 29/30psi front (2.1 front /2.2bar rear) anyone with an Evora should definitely try this pressure, the car feels even more planted to the road once tyres are warm I am running mine at around 34R & 31F if I recall. They seem to be wearing evenly across the tyre. you might want to change to thes pressures grip is really improved Link to comment Share on other sites More sharing options...
Steve J Posted August 13, 2014 Share Posted August 13, 2014 33 / 36 does seem a little high for a lightweight car. I run 20 / 23 on mine so 30 for a little extra weight doesn't seem too outrageous. Don't forget the tyres pressures increase when driving. Link to comment Share on other sites More sharing options...
G Posted August 13, 2014 Share Posted August 13, 2014 33 / 36 does seem a little high for a lightweight car. I run 20 / 23 on mine so 30 for a little extra weight doesn't seem too outrageous. Don't forget the tyres pressures increase when driving.I wouldn't say it's that lightweight steve ;-) Link to comment Share on other sites More sharing options...
mneil Posted September 10, 2014 Share Posted September 10, 2014 30 R and 29F seems better Link to comment Share on other sites More sharing options...
pa28pilot Posted September 18, 2014 Share Posted September 18, 2014 I believe that differing pressures are quoted for the standard (18" front / 19" rear) and option (19" front / 20" rear) wheel and tyre fittment. The lower profile options would be expected to run higher pressures. Link to comment Share on other sites More sharing options...
