Stig95 Posted June 6, 2014 Share Posted June 6, 2014 Hi all First off ill start with a confession. I have accidentally pull the trim off the roof bar that attaches above the door which the hood clips on to. What's the best adhesive for sticking it back on. It looks like lotus uses some sort of black adhesive? Secondly I have a rattle which seems to becoming from over my right shoulder towards the rear wheel, sounds like metal on metal such as someone running a stick along some railings, but it only does this one a certian strech of dual carageway. I've looked from the top but cannot see anything. Any ideas? Link to comment Share on other sites More sharing options...
dobbo Posted June 6, 2014 Share Posted June 6, 2014 I had a rattle that took ages to cure. I thought it was just behind my left ear, so near the window, but passengers said it was behind their left ear, so even further across to the left. Turned out to be the entire shear panel, under the fuel tank ! I took it off, covered all contact points with 1mm thick self-adhesive dense foam and rattle has gone. It can be really hard finding where rattles actually come from with these cars ! Link to comment Share on other sites More sharing options...
kayj_prod Posted June 7, 2014 Share Posted June 7, 2014 For the black adhesive, Tiger Seal? Link to comment Share on other sites More sharing options...
chris_h Posted June 7, 2014 Share Posted June 7, 2014 If you ever want to get it out again I wouldn't use tiger seal. Horrible stuff to remove! Link to comment Share on other sites More sharing options...
kayj_prod Posted June 7, 2014 Share Posted June 7, 2014 Isn't the point that the trim shouldn't come off? But yeah, grotty stuff, especially when you get it on your fingers! Link to comment Share on other sites More sharing options...
jonnyfox Posted June 10, 2014 Share Posted June 10, 2014 Charcoal canister makes a rattle behind your right ear. Link to comment Share on other sites More sharing options...
dobbo Posted June 10, 2014 Share Posted June 10, 2014 Only if it's fitted... :-) Link to comment Share on other sites More sharing options...
jonnyfox Posted June 11, 2014 Share Posted June 11, 2014 Yep ;-) Link to comment Share on other sites More sharing options...
