fentuz
Oil Light
Hi all,
After Snet yesterday (where I missed a gear and over reved), I took the car to work this morning.
Within a few miles, I noticed the stack oil indicator was glowing a little, not fully on. Within less than 1/2 mile, it went off without further signs. The EP Oil pressure gauge was showing 4bar and oil temp looked OK.
I have the EP higher pressure light sensor.
What do you think? Classic electrical thingy or a real oil problem?
Thanks
Bill
Share this post
Link to post
If your gauge is showing normal readings when cold and hot & at low and high RPM it is more than likely the sensor.
4 bar sounds ok, what does it drop to on tickover when warm ?
Share this post
Link to post
Sounds ok to me if there are no knocking or rumbling noises it will just be the sender.
Share this post
Link to post
