richbk
Need To Order New Battery Tonight
hi folks
as per title.
can anyone suggest a place to buy and type of battery to get for my exige.
happy to go lightweight if its worthwhile?
thx
richbk
Share this post
Link to post
If you are happy with only a week of battery reserve then the Odyssey pc680 is a good weight saving for not to much money. Not sure if they are cheapest currently but they were when I bought mine... http://www.active-robots.com/shop-by-brand/odyssey/enersys-odyssey-pc680.html
If you want a big weight saving then you need to go lithium.. http://www.carrotcycles.co.uk/index.php?_a=product&product_id=1648
Standard battery is approx 20kg £60, Odyssey 7kg £140, Shorai 2kg £300
Bet you can guess why I've been researching this, need to make the evora lighter!
Share this post
Link to post
Chris,
I've been looking at this for a while and keep wondering about:
Mounting: I don't thing either EP or ES have a battery mounting kits for these smaller batteries. I saw a French supplier has a kit but I need to do further diggings.
Connection: I want to retain the "original" connection so that I am free to return to a 206/306 battery if needed. I saw merlin sells adaptor so it's not a real issue
https://www.merlinmotorsport.co.uk/p/male-conversion-posts-for-20-25-35-batteries-pair-pvrbtm
Charging: how much charge can it take? can you go on holiday (or trackday trip) without worrying about the car starting on a cold morning?
Connection: It might be easy to fit an Anderson plug under the dashboard and run some battery cable to the battery and connect them in between the odyssey threaded connection and the merlin male adaptor.
Charger: would the halford charger be suitable to charge the odyssey. Or are the odyssey AGM type ?
EDIT: Just checked and Odysseys are AGM... About of interest, why some chargers are suitable for AGMs and some aren't?
Share this post
Link to post
I made my own aluminium bracket to hold my old 680. They have strong cranking on a cold morning and will last fine with even just a few minutes driving every few days. If left with no current draw they keep 80% of power for a year.
For the lithium they recommend running something that takes current for up to 30 seconds when really cold before cranking.
Share this post
Link to post
This seems to fit the bill????
http://www.ebay.co.uk/itm/Odyssey-PC680-PVR-Race-Battery-Bracket-posts-for-Std-fixing-Bundle-Deal-/151193198957?
I have a basic 12 /6 v trickle charger, that has kept my old battery well conditioned...... Until I forgot to turn it on in January !
Will it recharge the above or do I need to spend more £ on a new charger ,???
Thx
Rich
Share this post
Link to post
I'm tempted by that. Does anyone know what sort of charger you need for the odyssey battery?
Let us know how you get on if you order one would you please Rich?
Share this post
Link to post
I used a ctek designed for agm batteries. They don't make mine anymore but the new version seems to be the ctek mxs 3.8. You trickle charge it in the winter/agm mode.
Seem to be about £50 on web. They're good because they also come with quick connect cables to hard wire to the battery.
I'll need a different charger for my lithium so if anyone wants my charger I'd part with it for £30.
Share this post
Link to post
If you buy an Odyssey battery don't use a generic trickle charger. I fried my last one by leaving it on a standard 0.8 AMP charger. It needs to be 2.0 AMPS or more.
There's a lot of hype on the web about what trickle chargers you should and shouldn't use, but from experience and speaking to Odyssey suppliers as long as you go for chargers running at 2.0AMPS or above (and are AGM specific which the majority of 2.0 AMP chargers are) you'll be fine. I've got the C-Tek MXS 5.0 AMPS and it's perfect. Although they don't advise leaving it constantly on charge, just make sure it's full and then disconnect the earth lead if you're planning not to use it for a while.
I've had one sat on the shelf for over 12 months, put it in the car and it fired first time!
Chris - which I'd seen your post as I've only recently bought my MXS5.0 charger and yours would have been perfect!!
Share this post
Link to post
I've killed an Odyssey from using the wrong setting on the charger. Even on the AGM setting it struggles over the winter months the 340R sits in the garage. Might try disconnecting as you suggest Miles.
Share this post
Link to post
battery and bits ordered, after chat with sales guy at powervamp.
quiet impressed, they answered the phone at 8,18 am on a uk local rate number.
he explained need for charger of 2 amps...just not sure what mine is, so bit of research required.
so fingers crossed should be up and running on friday for a spring shakedown and bedding in the new discs and pads
richbk
Share this post
Link to post
Consider something like this: http://www.ebay.co.uk/itm/UNIVERSAL-CAR-Battery-Isolator-Cut-Off-Switch-/360762831858?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item53ff23f3f2
Attach to battery terminal, attach wire to isolator. Turn the knob and battery is disconnected.
Share this post
Link to post
Yeah have seen those. Trouble is my 340R doesn't have clamps and battery posts it has eyelets on the end of the battery cables and uses a bolt into the battery terminals like these:
odyssey-pc680-12v-18ah-agm-battery-%5B3%
Share this post
Link to post
I was advised by a number of people that the two ways to kill or shorten the life of an Odyssey battery is to use a charger of only 0.8AMPS (which fried mine!) or to leave it constantly connected (even to an AGM charger).
They said to charger it up fully using the proper charger and then remove the charger and disconnect the battery - I simply disconnect the negative wire - takes 30 seconds with an alan key headed socket. I have left the battery for 6-12 months in the past (PC680 like in your post) and it fired first time on re-connecting.
Share this post
Link to post
So Rich, what battery did you go for in the end? Was it easy to fit? How are you finding it so far?
Share this post
Link to post
  • Similar Content
    • By DeanB
      I could do with an indoor car cover for the elise. It will be coming home soon with new paint and I don't want it damaged.
      There is a window in the garage so uv light might be a teeny issue but mostly it is to protect it from the cats that like to walk all over it.
      Any suggestions?
      Thanks folks ☺
      Dean
    • By DeanB
      I am after a harness bar for my s2 but don't want to buy the wrong one. Do any of you have any recommendations? I will be using a bolt-in harness on the driver's side only, probably with some sort of motorsport seat.
      On a related topic, have those of you with harnesses removed or retained the oem seatbelts? Is it possible to have both?
      And (finally!) what about seat mounting? Are there any recommended solid seat mounts? My existing runners/mounts are noisy, and seeing as the car is going to be for occasional use with hopefully more trackdays now I can live without sliding the seat back to ease ingress/egress every time. I thought sitting a tad lower would be good, as would saving a bit of weight with the mounts. Any ideas?
      Thanks in advance guys.
    • By DeanB
      I am thinking of getting a new back box, for a nicer sound, a weight saving, and to look nice.
      It wants to be:
      -as light as poss
      -single exit
      -not too loud
      -not boomy or droney
      Any ideas guys and gals?
      Ta
      Dean
