daves2111s Posted December 29, 2013 Share Posted December 29, 2013 Had mine fitted by DRM when the clam was off for suspected HGF & 4:2:1 Having watched it being done I would not fancy the job with the clam still on. Even on the S2 it's a bit of a pain to fit properly. Link to comment Share on other sites More sharing options...
AlanS1 Posted December 30, 2013 Author Share Posted December 30, 2013 Car is now back on axle stands to inspect the clearance issues further. With the very appreciated help from Jody, new uprated gearbox mount and adjustable engine steady now fitted. I now have around 15-20mm of clearance now. A lot better but still not as much as i want. The main engine mount is now removed and these bushes are also worn. Also the standard mount i have is slightly offset towards the bulkhead. I have decided to buy the Elise parts uprated mount (not the vibratecknik one though). This mount sits more central and should in theory bring my engine back a bit further. I imitated where this mount should position my engine and this should give me the clearance needed. (hopefully). Once this is fitted i need to secure the lower coolant pipe to the bulkhead with a more permanent method. (Jody has come up with a great idea here). Thanks Alan Link to comment Share on other sites More sharing options...
