MilesH Posted December 5, 2013 Share Posted December 5, 2013 Miles, thanks for that. Do you fancy Zandvort next year? I could do with another driving lesson. I'd love to join you, and the current K-Series car that's in my garage is quiet enough to pass the noise regs Let's make a plan............ Link to comment Share on other sites More sharing options...
Martin R Posted December 5, 2013 Author Share Posted December 5, 2013 I'd love to join you, and the current K-Series car that's in my garage is quiet enough to pass the noise regs Let's make a plan............ I will put a post in events to gauge interest. Liz and i will be going. We will make a small holiday of it no doubt again. I dont think they have a lot of problems at Zandvort re noise. Link to comment Share on other sites More sharing options...
DeanB Posted December 5, 2013 Share Posted December 5, 2013 Martin are you having heavy metal inserts in your crank? A mate of mine builds old Triumph engines for a living (most of them for historic racing TRs and Morgans) and he swears by Vibration Free. Link to comment Share on other sites More sharing options...
Martin R Posted December 5, 2013 Author Share Posted December 5, 2013 Dean at approx 1.5K for balancing with heavy metal inserts its not possible for me. The standard balanced crank has lasted 55K without. It should be better than OE balancing as Steve balances the complete assembly, including clutch plates, flywheel, crank, front damper etc etc Link to comment Share on other sites More sharing options...
jimbo07g41 Posted December 5, 2013 Share Posted December 5, 2013 Martin getting the engine rebuilt by DVA is a good decision. I think it will be a good investment. S2 190's will only go up in value. I am sure you could have done it yourself but having a DVA rebuild in the history, will help it keep its value. Not that you will ever sell! Link to comment Share on other sites More sharing options...
Martin R Posted December 5, 2013 Author Share Posted December 5, 2013 Jamie, good point. However by the time i have finished with it i doubt it will be worth much. To keep it appreciating, you cant use one really. It gives me far too much pleasure not to use. It also makes me swear when crawling about on a cold garage floor in the winter. Its all part of the ownership experience to me Link to comment Share on other sites More sharing options...
jonnyfox Posted December 5, 2013 Share Posted December 5, 2013 Great stuff Martin but I think that bulkhead needs some Gold Blinger there buddy ;-) Link to comment Share on other sites More sharing options...
DeanB Posted December 5, 2013 Share Posted December 5, 2013 £1.5k!! Bloody hell! At least you won't have to worry about any of that heavy metal coming adrift - which wouldn't be pretty. I'm sure that would be unlikely but I would worry if it were done on mine. Link to comment Share on other sites More sharing options...
Martin R Posted December 6, 2013 Author Share Posted December 6, 2013 Great stuff Martin but I think that bulkhead needs some Gold Blinger there buddy ;-) I had enough Gold bling with Bis and then you and Dan start Seriously though, i would have considered it on any other one. Im trying to keep it OE ish as its a fairly limited edition car. I dont know why as it will make no difference to the value the amount i use it. Its just the way i feel. Anything i do to take it away from OE i keep to return if needed. I would have gone for Silver anyway. There is bling and there is bling Edit, i have popped the engine spec now on the first post Link to comment Share on other sites More sharing options...
danwebster Posted December 11, 2013 Share Posted December 11, 2013 As Martin mentioned earlier I was refurbing the box I thought I'd share the process with you here. First of all I fully dismantle the box as all of the bolts and various brackets will be blasted and then sent for electro plating. Once the box is open the familiar black residue is visible and it stinks like someone has been to the toilet inside it....standard stuff for gearboxes unfortunately! All of the innards were then removed and washed thoroughly in the parts washer, and then finally the case is given a good wash first in the parts washer and then in the hot wash. Prior to media blasting the case looks like this, clean on the inside but still showing signs of corrosion on the outside. Then after a few hours of media blasting with coarse grit, followed by Aqua blasting with fine grit then back into the parts washer, then into the hot wash, the case looks better than new! I also did a few other assorted odds and sods as well... Now we just need a few bearings and seals and the whole thing can be reassembled. You better not get it dirty after all that effort Martin! Link to comment Share on other sites More sharing options...
Martin R Posted December 11, 2013 Author Share Posted December 11, 2013 Dan, looks shiny. You could have hours of fun with the washing machines Link to comment Share on other sites More sharing options...
danwebster Posted December 11, 2013 Share Posted December 11, 2013 Fun is questionable....but the results are good! You do need 40 grands worth of kit mind you....! Link to comment Share on other sites More sharing options...
danwebster Posted December 27, 2013 Share Posted December 27, 2013 A few pics of the rebuild, I only took a couple as I got a bit carried away with putting it back together. Martin supplied all of the bearings to fully rebuild the gearbox which in theory should mean it would go straight back together with all the same shims in, but you can't take these things for granted so all the clearances are checked, in this case with eye wateringly expensive Mitutoyo kit - f1 team standard stuff. Fortunately everything was within factory tolerances but when the tolerance is 0.15 of a millimeter then it pays to check! Then with all the internals spotlessly clean it can go back together. I haven't taken any pics of the finally assembled box but I must say it looks rather splendid, I'll take a pic in the daylight! Link to comment Share on other sites More sharing options...
Matt C Posted December 27, 2013 Share Posted December 27, 2013 Good work Dan - looks a cracking job. Link to comment Share on other sites More sharing options...
Martin R Posted December 27, 2013 Author Share Posted December 27, 2013 Dan, nice work Im never going to drive it in the rain again. Link to comment Share on other sites More sharing options...
