Alex B Posted November 21, 2012 Share Posted November 21, 2012 Noticed at the weekend my car was letting a little bit of water in during heavy water fall. I know the roof had had a new front tension wire so I thought I might now have been tightened enough as the roof dis not sit 100% right. Well I managed to get roof sat right however it now seems to leak a bit more than it did. After a bit of investigation it seems the windows do not meet with the rubber roof seals across the whole edge of the roof. Any one had this problem ? Or know of a solution? Link to comment Share on other sites More sharing options...
scatty Posted November 21, 2012 Share Posted November 21, 2012 In sure you can lift the windows slightly. Obviously no Idea how. Mine did the same and was very drafty as well. Gav managed to make it better. I think it's a common thing. Link to comment Share on other sites More sharing options...
DeanB Posted November 21, 2012 Share Posted November 21, 2012 Mr Simba has a little fix for this. Maybe you could PM him? On a different subject Alex, you ought to fit a PRT remote thermostat. They reduce the risk of thermal shock to the engine when the thermostat opens, and are oem on late model cars (not Lotus) using the 1.8k series. They help to prevent HGF. Will cost you about £120 from Eliseparts or Hangar 111 and Gav at Unit4 will fit it for you in a couple of hours. He did mine. While you're there I would have him give your car a good look over while it is on the lift, just to see that all is well. Worth it for peace of mind. And he will adjust your windows for you. He isn't dear. Link to comment Share on other sites More sharing options...
kayj_prod Posted November 21, 2012 Share Posted November 21, 2012 Electric windows or old skool manual? Link to comment Share on other sites More sharing options...
Alex B Posted November 21, 2012 Author Share Posted November 21, 2012 its an S2 with eletric windows. Mr Simba has a little fix for this. Maybe you could PM him? On a different subject Alex, you ought to fit a PRT remote thermostat. They reduce the risk of thermal shock to the engine when the thermostat opens, and are oem on late model cars (not Lotus) using the 1.8k series. They help to prevent HGF. Will cost you about £120 from Eliseparts or Hangar 111 and Gav at Unit4 will fit it for you in a couple of hours. He did mine. While you're there I would have him give your car a good look over while it is on the lift, just to see that all is well. Worth it for peace of mind. And he will adjust your windows for you. He isn't dear. will PM Mr Simba. with reguards to the PRT im not sure how it will affect my 12month dealer warranty, will speak to them and ask. will take it to unit 4 once i've been paid to have the once over. Link to comment Share on other sites More sharing options...
russelld Posted November 21, 2012 Share Posted November 21, 2012 Have a look here. http://wiki.seloc.org/a/Window_adjustment Link to comment Share on other sites More sharing options...
Alex B Posted November 21, 2012 Author Share Posted November 21, 2012 will give this a try as soon as i get 5min, it does look like my windows arent high quite high enough. i willl also try the window tilt adjustment. my dad pointed out my windows looked low, when i first noticed the leak. Link to comment Share on other sites More sharing options...
John FISH Curtis Posted November 21, 2012 Share Posted November 21, 2012 I loosened the bolts for the window inside the door, then taped the top of the window to the top hood section. Get someone to push the glass against the rubber seals, then tighten the bolts inside the door. Link to comment Share on other sites More sharing options...
MrSimba Posted November 22, 2012 Share Posted November 22, 2012 Mr Simba has a little fix for this. I found that no matter how I adjusted the window there was still a slight leak, so ordered some self adheasive aircraft door seal and put it along the edge of the rubber where the glass 'butts' up to the soft top. It works a treat, I can hose the car down whilst washing it now and no water enters the cabin and is totally unnoticeable on the car, looks totally 'OE' http://www.parts4air...p?ItmID=9382950 Link to comment Share on other sites More sharing options...
Alex B Posted November 23, 2012 Author Share Posted November 23, 2012 I found that no matter how I adjusted the window there was still a slight leak, so ordered some self adheasive aircraft door seal and put it along the edge of the rubber where the glass 'butts' up to the soft top. It works a treat, I can hose the car down whilst washing it now and no water enters the cabin and is totally unnoticeable on the car, looks totally 'OE' http://www.parts4air...p?ItmID=9382950 any chance of a picture of your mod? have gone to adjsut the tilt on my window via the twit screws (acessable without removing trim) and only 1 on each side will work the two rear ones are seized. Link to comment Share on other sites More sharing options...
MrSimba Posted November 23, 2012 Share Posted November 23, 2012 See if I can take one at the weekend, not much to see tho tbh! Link to comment Share on other sites More sharing options...
MrSimba Posted November 25, 2012 Share Posted November 25, 2012 Crappy camera phone pics but you'll get the idea! Link to comment Share on other sites More sharing options...
Alex B Posted November 25, 2012 Author Share Posted November 25, 2012 Thanks ordered some Saturday evening so should hopefully have it solved when it turns up. Link to comment Share on other sites More sharing options...
Alex B Posted November 28, 2012 Author Share Posted November 28, 2012 Weather strip has turned up just gotta fit it now. Link to comment Share on other sites More sharing options...
