Stumason10 Posted October 22, 2012 Posted October 22, 2012 Need to trail brake the mower to get all that weight over the front....Then back end will step out and correct with power.........or a spin....
Steve J Posted October 22, 2012 Posted October 22, 2012 Problem is the clutch and brake are the same pedal so need to hard on the gas all the time. Think I've spent more time on my mower than in the exige.
Stumason10 Posted October 22, 2012 Posted October 22, 2012 Better get the exige out then....fit a tow bar and get one of those drag mowers....Sorted!!
R.I.B. Posted October 24, 2012 Posted October 24, 2012 A good geo might do it! More negative camber and a bit of toe out at the front
lummo Posted October 25, 2012 Author Posted October 25, 2012 A good geo might do it! More negative camber and a bit of toe out at the front I'm not entirely sure this will work. Especially when you consider that the front wheels are only held on the axle by a washer & a split pin.
rocketian Posted October 26, 2012 Posted October 26, 2012 Seems to me it may need a rear wing attaching??? Carbon obviously! siiiiiigh Oh dear ... Rear wing wont help understeer - just make it worse. It is the front end grip that needs improving not the rear. What we ought to be considering is some winglets on the grass box
Stumason10 Posted October 27, 2012 Posted October 27, 2012 MLOC winter lawnmower championship anyone?!! Not sure my bosch mini mower will be competitive as I have to push it......?! 1) Steve J 2) Lummo........
scatty Posted October 27, 2012 Posted October 27, 2012 Il have to give it s miss this year, ever since I over filled it with oil, I seem to explode in a power of smoke after 2 laps and need it to cool down!!! This is why I don't tinker with my car!!!!
G Posted October 28, 2012 Posted October 28, 2012 Il have to give it s miss this year, ever since I over filled it with oil, I seem to explode in a power of smoke after 2 laps and need it to cool down!!! This is why I don't tinker with my car!!!! Do you have any mayo in the coolant bottle? Sounds like HGF?
