graeme_laslett Posted August 25, 2009 Share Posted August 25, 2009 Hi all, Sorry for the really dumb question, but I got hold of a rear tow eye (a silver version of one of these http://www.eliseparts.com/products.php?product=606), but how do you attach it to the car??? All I know is that it mounts to the strongest part of the rear subframe, but where is that? Do you have to remove the undertray? Am I missing something very obvious? Thanks in advance G Link to comment Share on other sites More sharing options...
Dr H Posted August 25, 2009 Share Posted August 25, 2009 Should be the largest botls in the undertray. If it's like my S2 they are two large bolts, much bigger then the outer fixings. Link to comment Share on other sites More sharing options...
graeme_laslett Posted August 25, 2009 Author Share Posted August 25, 2009 Thanks Dr H Just to confirm, the bolt marked as Diffuser to Subframe fixing below? Link to comment Share on other sites More sharing options...
Stumason10 Posted August 25, 2009 Share Posted August 25, 2009 Thanks Dr H Just to confirm, the bolt marked as Diffuser to Subframe fixing below? That's the one......That is where mines bolted to! Link to comment Share on other sites More sharing options...
graeme_laslett Posted August 25, 2009 Author Share Posted August 25, 2009 Thanks Guys, Just seemed a little too far under the car, so thoughr I had better check G Link to comment Share on other sites More sharing options...
Reg Posted August 25, 2009 Share Posted August 25, 2009 Aparently they rust as well......... Link to comment Share on other sites More sharing options...
Steve J Posted August 25, 2009 Share Posted August 25, 2009 Indeed they do Link to comment Share on other sites More sharing options...
Reg Posted August 25, 2009 Share Posted August 25, 2009 Indeed they do Although Graeme say's his is silver, so it might not rust................... Link to comment Share on other sites More sharing options...
Stumason10 Posted August 25, 2009 Share Posted August 25, 2009 Although Graeme say's his is silver, so it might not rust................... Mine is Red from EP?! Will rot eventually mind! Link to comment Share on other sites More sharing options...
graeme_laslett Posted August 26, 2009 Author Share Posted August 26, 2009 Best "upgrade" I have fitted..... ended up in the gravel at Oulton Park this afternoon and had to be dragged out backwards!!!! Thanks again for pointing out where it went. G Link to comment Share on other sites More sharing options...
