Mish Posted September 18, 2006 Share Posted September 18, 2006 Hi, My S1 '98 Elise is making a loudish rattling noise when rev'ed @ 1500rpm even whilst stood still, at first I thought it was the rear undertray which is still rattling as I'm in the process of finding some bolts to sort it but its not. It sounds like its coming from the cocktpit side of the engine and is like a loudish rattle, I'm thinking its something like a loose heat shield... Any ideas anyone? Any common faults like this, loose bits etc.? Temperature is at a constant 84 degrees, theres loads of water, oil is at max and it drives really well so I didn't think it was anything major but it is a little un-nerving, only seemed to be happening tonight, I have not heard it before.... Many thanks in advance, H Link to comment Share on other sites More sharing options...
Snapper Posted September 18, 2006 Share Posted September 18, 2006 get someone else in the throttle while you look. is the best advice I can give. Link to comment Share on other sites More sharing options...
Mish Posted September 18, 2006 Author Share Posted September 18, 2006 I've been moving the throttle with the cable on the engine so I can hear it..... Link to comment Share on other sites More sharing options...
sootysteve Posted September 18, 2006 Share Posted September 18, 2006 mine does it at 2000 ish rpm, its the downpipe probably, thats what i think mine is, its a common problem with the flexi bit, esp if its the original down pipe. Link to comment Share on other sites More sharing options...
Martin R Posted September 18, 2006 Share Posted September 18, 2006 Hamish, take both of the rear undertrays off and try it again. The cables underneath are well known to cause rattling noises. Link to comment Share on other sites More sharing options...
Integra99 Posted September 18, 2006 Share Posted September 18, 2006 Hamish, take both of the rear undertrays off and try it again. The cables underneath are well known to cause rattling noises. Yep very likely braiding on the downpipe coming apart which touches the undertray making an awful noise. Link to comment Share on other sites More sharing options...
dss123 Posted September 19, 2006 Share Posted September 19, 2006 Coins under the seats?? Take her for a spin, brake hard (when safe to do so), then pick them all out from just behind the cross member. You never know??? Dunc Link to comment Share on other sites More sharing options...
jeffers Posted September 19, 2006 Share Posted September 19, 2006 Mine did the same and it was the heatshield on the exhaust manifold. Give it a wiggle and check for movement. Link to comment Share on other sites More sharing options...
25oly Posted September 21, 2006 Share Posted September 21, 2006 Mine did the same and it was the heatshield on the exhaust manifold. Give it a wiggle and check for movement. Yep Mine to Just come from under mine as the heat sheild had corroded round one of the nuts and was resting on the under tray, just fixed the badger back on and the noise has gone. Just take the rear wheel of and give it a wiggle even when its fixed where it should be it only gives 1cm gap btween the under tray so not much room for movment. Link to comment Share on other sites More sharing options...
Mish Posted September 21, 2006 Author Share Posted September 21, 2006 Thanks for the replys guys, I HAVE FOUND THE RATTLE!!! yey!!!!! Is the joint between the downpipe and the next bit of exhaust. I'm gonna have to get the car jacked up, get under there and tighten them me tinks.. I was wondering what do people recomend to put on the bolts...like a locktight or somthing like that?? I was going to remove and clean them before re-fit....I'm sure I've heard of people using sealants etc. on exhausts????????? H Link to comment Share on other sites More sharing options...
Martin R Posted September 21, 2006 Share Posted September 21, 2006 Hamish, you can use a sealent but it should really be a last resort. When you take it apart there should be a stainless steel gasket between the 2 parts. That is normally enough to seal the joint. If its the one between the manifold and flexy section it can be a pain to get at. You will need a long extension with a knuckle joint on. Good luck Link to comment Share on other sites More sharing options...
sootysteve Posted September 21, 2006 Share Posted September 21, 2006 mine buzz's at around 2000 rpm it drives me absolutely mad i noticed mine when i had the eliseparts silencer put on last yr, i guess due to it being more boomy, my answer to it i thinks is a 4-2-1! Link to comment Share on other sites More sharing options...
cks1 Posted September 23, 2006 Share Posted September 23, 2006 I have this problem to but mine is a split heat shield and my gid it annoys me! a friend had the same problem and took the shield off only to burn the reflective heat shielding on the fire wall........... Link to comment Share on other sites More sharing options...
