AndyS Posted April 5, 2006 Posted April 5, 2006 Hi Mark, Same experienced under Wide and Narrow. However, I have turned the RTE off and it now works fine. Cheers. Was going to say was suffering the same problem (suspect CWD issue) now where is that RTE off switch?? Edit found it I hope.) http://www.midlandslotus.co.uk/forum/index...=UserCP&CODE=04 Option to switch it off is at the bottom Yup, that's where I found it and yes that cures the problem with Work computer!
Mark H Posted April 5, 2006 Author Posted April 5, 2006 Good good, will make the normal editor default when I get a chance then and people can switch on the RTE if it works for them, seems to cause less problems!
darren5591 Posted April 5, 2006 Posted April 5, 2006 On the previous version, when you hovered over the post it showed a preview,it allowed me to realise if the post was worth reading,this version seems not to have this feature
Mark H Posted April 5, 2006 Author Posted April 5, 2006 On the previous version, when you hovered over the post it showed a preview,it allowed me to realise if the post was worth reading,this version seems not to have this feature Yeh it does, you just need to choose the skin with it switched on, choose the topic preview skin from the bottom left.
