Bobjacqs Posted January 12, 2016 Share Posted January 12, 2016 Hi, There are dead flies behind my headlight covers. Is my best bet to remove the covers and clean behind them or is it easier to remove the headlamps? It's a 1997 Elise (manufactured 1996) and I read somewhere that the covers were bonded in place in the early Elises - not sure how to tell. Cheers Bob Link to comment Share on other sites More sharing options...
dobbo Posted January 12, 2016 Share Posted January 12, 2016 Not a standard fit, so could be glued on with anything ! I'd remove the lights to clean. Count the turns on each butterfly but and you'll be pretty close to correct headlight alignment on refitting. Link to comment Share on other sites More sharing options...
willgriffin1983 Posted June 8, 2016 Share Posted June 8, 2016 Trying to get the headlamp covers off without damaging the paint work or cracking the covers could be difficult-removed my for a clam refresh and never bothered to replace them due to dust, flies etc. getting behind again. Link to comment Share on other sites More sharing options...
Jonathan E Posted June 11, 2016 Share Posted June 11, 2016 Do as dobbo says above, then fit a pair of these: https://www.eliseparts.com/products/show/16/866/headlamp-foam-seal/ Fitted them on all of my S1's they do a great job and will solve your problem Alternatively use some fishing wire to cut through the cack they are stuck on with, if its the same stuff as Eliseparts sell it will clean off pretty well, but as above if some numpty has used tiger seal etc then it will be a long job. Link to comment Share on other sites More sharing options...
