Thomas Harborne Posted September 23, 2015 Share Posted September 23, 2015 Hi all, went to start the car tonight. The stack shimmers as normal, all the lights are on and the immobiliser red led is activebut when turning the key all that happens is a noise at the back which im guessing would be the fuel injecting? I know its hard to give any sort of diagnostics but has anyone any ideas? Link to comment Share on other sites More sharing options...
dobbo Posted September 23, 2015 Share Posted September 23, 2015 A chattering ? Low battery - not enough to turn the starter motor. Link to comment Share on other sites More sharing options...
Thomas Harborne Posted September 23, 2015 Author Share Posted September 23, 2015 A chattering ? Low battery - not enough to turn the starter motor. Battery is fine Dobbo, had it drop tested the first week i had it when i had a loose connection on 1 of the terminals. I've just checked all fuses, fine. Tried it again and blam she fired up no problem!! Very strange. Used it the weekend and it was perfect all day Saturday. Link to comment Share on other sites More sharing options...
dobbo Posted September 23, 2015 Share Posted September 23, 2015 If the fuel pump primes, that's only for a few seconds and it's a buzzing noise from the car not the engine bay. If you turn the ignition off and on again after a few seconds, it won't prime again. If it's not that noise, the only other thing that goes when you turn the key is the starter motor. It's possible (but VERY unlikely) that it failed to engage with the ring on the flywheel and kept bouncing off the teeth on the flywheel. Might explain why it's started now. I assume the red led went out when you were trying to start it? If not, I think (not sure) that the fuel pump still primes but obviously won't start if the immobiliser is still active (ie red led still on). Link to comment Share on other sites More sharing options...
@ndy Posted September 23, 2015 Share Posted September 23, 2015 Check the spade connector on the starter motor is secure on it's terminal, If this is not tight then the starter wont spin up, I've had this on mine and just needed to squeeze it slightly with some pliers. Link to comment Share on other sites More sharing options...
Thomas Harborne Posted September 23, 2015 Author Share Posted September 23, 2015 Cheers ill check connections on the starter tomorrow when i get time. Yes the LED goes out once i press the key fob and turn the key to start. Link to comment Share on other sites More sharing options...
kieranexige Posted September 23, 2015 Share Posted September 23, 2015 Had the same as Andy on a friends car.... Left it on my drive after a bbq, next morning nothing. After a volt check I saw that the spade connector had broken in half off the starter terminal. Link to comment Share on other sites More sharing options...
Alex B Posted September 25, 2015 Share Posted September 25, 2015 Check the spade connector on the starter motor is secure on it's terminal, If this is not tight then the starter wont spin up, I've had this on mine and just needed to squeeze it slightly with some pliers. Very common fault, happened to me while in Le Mans and also MartinR while at curborough earlier this year. Link to comment Share on other sites More sharing options...
