Martin R Posted July 23, 2015 Share Posted July 23, 2015 Does not look like mayo to me. Can you do a decent pic of the coolant bottle? Link to comment Share on other sites More sharing options...
AndyPeat Posted July 23, 2015 Author Share Posted July 23, 2015 It's not now, it started with a bit of mayo emulsified oil but then a shed load of brown oil appeared (quarter of an inch in the expansion tank), after clearing it out with a rag, the next time I checked it had mostly gone as there was inevitably some left after cleaning it. I took it for a blast tonight and some of the oil is back but not as bad as before. Here's a couple of pics. It ain't good by the looks of it. This is after a decent run after it had cleared. Link to comment Share on other sites More sharing options...
Martin R Posted July 23, 2015 Share Posted July 23, 2015 Blow across the fire ring IMO http://arc.seloc.org/viewthread.php?tid=264676 Is the coolant system retaining pressure after a good run? Link to comment Share on other sites More sharing options...
AndyPeat Posted July 23, 2015 Author Share Posted July 23, 2015 Seems ok. Plenty of hissing when the cap is removed slowly. I'll have to have a look at the seloc link later. I can't remember my log in. Link to comment Share on other sites More sharing options...
Martin R Posted July 23, 2015 Share Posted July 23, 2015 Take it for a good run. After a couple of hours slowly remove the coolant cap. Let us know what happens? Link to comment Share on other sites More sharing options...
AndyPeat Posted July 23, 2015 Author Share Posted July 23, 2015 Will do. Thanks for the input guys... Link to comment Share on other sites More sharing options...
AndyPeat Posted July 24, 2015 Author Share Posted July 24, 2015 Let it cool down for a couple of hours after my run to work and there was hissing when the cap came off. I've spoken to Gav at Unit 4 this morning. Whatever it is it's not right and I need to give it the best chance so it's going there in the morning and I'll leave it with him while I'm on holiday. From what I've read here I'm sure it's in good hands. I'll post any developments Thanks all Link to comment Share on other sites More sharing options...
Martin R Posted July 24, 2015 Share Posted July 24, 2015 If there was a lot of hissing its almost certainly blowing across the fire ring and pressurizing the coolant system. Its caused by an indent on the head normally on the exhaust valve side. The head gets hottest at this point. Link to comment Share on other sites More sharing options...
DeanB Posted July 24, 2015 Share Posted July 24, 2015 Gav is good. He repaired my hgf. My car is there at the moment for a new radiator. He will have the head skimmed, hopefully that will sort it. He has repaired literally hundreds of hgf over the years so knows from experience what works and what doesn't. Mine has done 23,000 miles since he fixed it... Link to comment Share on other sites More sharing options...
AndyPeat Posted July 24, 2015 Author Share Posted July 24, 2015 Thanks Dean, it's reassuring to hear. I feel that all the chips are all in this time financially after what will be three head removals and two skims so I might as well spend more and get the best job for peace of mind. If this doesn't work out it's webuyanycar.com. I've had her 12 years now with nearly no trouble so I can't grumble too much Link to comment Share on other sites More sharing options...
Meister Posted July 24, 2015 Share Posted July 24, 2015 My second home is now Gav's, he'll put you right and for a fair price.Mark Link to comment Share on other sites More sharing options...
AndyPeat Posted August 25, 2015 Author Share Posted August 25, 2015 Quick update, gav has had her for a while now, trying to rule out anything other than the gasket, heat exhanger (oil cooler) had been ruled out by bypassing. Head's off today, the work carried out previously looks solid and the head skim looks very good. Liner heights all spot on. No obvious signs of where it's coming from. So it's a bit of a head scratcher. We're hoping the Payen gasket will sort it as it's more forgiving than the multi layer one. Should get it back next weekend after testing Fingers crossed! Link to comment Share on other sites More sharing options...
The Working Man Posted September 5, 2015 Share Posted September 5, 2015 Have the head hardness tested why it's off. It's a pretty easy process. When a k series has overheated it can cause soft spots. Anything less than 95 grinall and the head is scrap, no matter what you do to it. Just noticed the date of this thread, advice may be a little late, hope you're sorted. Link to comment Share on other sites More sharing options...
AndyPeat Posted September 6, 2015 Author Share Posted September 6, 2015 Thanks Working Man but I got the car back yesterday, Gav said a fair bit of oil came through on first test which was a bit of a worry, but it looks like it was just residual oil in the system. It's had a couple of flushes since then and he had it running for around 4hrs on Friday with no additional oil appearing. He's 90% sure it's resolved. I've been out in it quite a bit since and still looking good. so fingers crossed. Thanks for all the input folks. Just like to add that I've been impressed with Gav's work and how he methodically approached the problem. It was good value. Another thumbs up from me! ! Link to comment Share on other sites More sharing options...
1959triumph Posted September 8, 2015 Share Posted September 8, 2015 The oil feed in the block can leak in to the water, there is stuff on seloc dave andrews at dva is the expert he has a fix involving drilling it out and inserting a pipe. Link to comment Share on other sites More sharing options...
