AndyPeat Posted July 15, 2015 Share Posted July 15, 2015 Just had quite a bit of work done to the elise: New clutch, clutch release arm, timing belt and pump, head skim and new gasket with the uprated oil rail/ladder. My mechanic is a good guy (one of the head mechanics at Sytner) he did it in his spare time. The system has had a coolant cleanser and flushed. I'm very happy now with how the elise runs but I'm getting some gunk in the expansion tank. I'm not losing coolant as the level appears constant. Just wondering what it might be, the heat exchanger was pressure tested on the last head gasket change (took it somewhere last year to get the gasket changed and he made a pig's ear of it, still leaked) so I don't think it's that. Any ideas? Link to comment Share on other sites More sharing options...
russelld Posted July 15, 2015 Share Posted July 15, 2015 There could be some porosity in the head around the fire ring. Peening the head before skimming can cure this. This normally pressurises the system rather than create mayo. It could of course just be old gunk working it's way through, some that was missed when flushed. I shall keep my fingers crossed for you :-) Link to comment Share on other sites More sharing options...
AndyPeat Posted July 15, 2015 Author Share Posted July 15, 2015 Thanks Russell, I shall to I could do without another skim Link to comment Share on other sites More sharing options...
Martin R Posted July 15, 2015 Share Posted July 15, 2015 Quite possibly old gunk. I doubt you can flush the system fully. Might be out the heater matrix. Dont panic yet Link to comment Share on other sites More sharing options...
AndyPeat Posted July 15, 2015 Author Share Posted July 15, 2015 I bloody hope so, two new head gaskets in a year, it's no fun. I might get the expansion tank 'sniffed' for exhaust fumes. Link to comment Share on other sites More sharing options...
un1eash Posted July 15, 2015 Share Posted July 15, 2015 Nearly 3 years and 5k miles later and I still get a bit of gunk in the header tank on my 111S. Head gasket was replaced by Olly at Phoenix Motorsport. Link to comment Share on other sites More sharing options...
AndyPeat Posted July 15, 2015 Author Share Posted July 15, 2015 Thanks for the info. Just spoken to Unit 4 at Burton, he's told me not to panic yet. Link to comment Share on other sites More sharing options...
AndyPeat Posted July 17, 2015 Author Share Posted July 17, 2015 Sh*t, it's getting worse. Just dipped my finger in to the expansion tank (see pic) Spoke to Unit 4 and he said I should clear out the tank and bypass the heat exchanger just in case it's that. If not it's the head off for the third time. Link to comment Share on other sites More sharing options...
Legacystorm Posted July 22, 2015 Share Posted July 22, 2015 I've always believed u shud Nvr skim k series head coz once u take hrd top layer of surface underneath is softer n can cause issues Link to comment Share on other sites More sharing options...
Alex B Posted July 22, 2015 Share Posted July 22, 2015 Sh*t, it's getting worse. Just dipped my finger in to the expansion tank (see pic) Spoke to Unit 4 and he said I should clear out the tank and bypass the heat exchanger just in case it's that. If not it's the head off for the third time. What sort of distance are you travelling in the car? Link to comment Share on other sites More sharing options...
AndyPeat Posted July 23, 2015 Author Share Posted July 23, 2015 Just locally my commute is 16miles round trip but I only use it 2-3 times per week. The odd thing is that once I cleared out the oil it hasn't come back, maybe it's mixing with the coolant now but as you can see from the pic, it wasn't mixed, just dark brown. I'm taking it steady for the next week to monitor it and then I'll put my foot down a bit. Link to comment Share on other sites More sharing options...
russelld Posted July 23, 2015 Share Posted July 23, 2015 Trash it now. If there is a problem it won't go away by taking it easy and you need to know for sure. Link to comment Share on other sites More sharing options...
AndyPeat Posted July 23, 2015 Author Share Posted July 23, 2015 You're right, I'm picking my lad up from school today, I'll take him for a blat around. Link to comment Share on other sites More sharing options...
russelld Posted July 23, 2015 Share Posted July 23, 2015 Good luck Link to comment Share on other sites More sharing options...
Alex B Posted July 23, 2015 Share Posted July 23, 2015 Trash it now. If there is a problem it won't go away by taking it easy and you need to know for sure. Russ is on the same wave length. Best case it's just residue and will burn off. Worst case it's something more sinister and it will need fixing anyway, just take your AAcard with you. Link to comment Share on other sites More sharing options...
