AndyPeat Posted July 16, 2015 Share Posted July 16, 2015 Ta, but resistor pack symptom is that some speeds work, while others don't. If all of them go/come back at the same time, it's gona be something else Dan Double bugger! Are you talking about the resistor pack, or the fan relay? Sorry, I was talking about the resistor pack. I'll go back to bed now... Link to comment Share on other sites More sharing options...
StormS2 Posted July 16, 2015 Author Share Posted July 16, 2015 £800!the car has had a uprated alloy radiator fitted which I've got to say is so much better than the oem one,keeps engine temps much lower,the fan obviously broke after the rad was done I'm guessing,think I'm going to have to start phoning round for quotes:( Link to comment Share on other sites More sharing options...
Simon Mac Posted July 17, 2015 Share Posted July 17, 2015 £800!the car has had a uprated alloy radiator fitted which I've got to say is so much better than the oem one,keeps engine temps much lower,the fan obviously broke after the rad was done I'm guessing,think I'm going to have to start phoning round for quotes:( Bear in mind that was a main dealer, and they could charge top dollar as it was going to a lease company. I didn't keep the invoice, but IIRC it was <£40 in parts, the rest was main dealer labour rates. Could you get a mate round and have a "clam off" party? Seeing the work you did with your rear diffuser panel this seems like it could be within your DIY levels, but you need two people. http://wiki.seloc.org/a/Remove_S2_front_clamshell Link to comment Share on other sites More sharing options...
StormS2 Posted July 17, 2015 Author Share Posted July 17, 2015 That seems a lot of work,the thing that'd worry me is that everything went back correctly! can't believe all that just to fix a fan heater,are these definitely not accessible when removing the undertrays? Link to comment Share on other sites More sharing options...
Simon Mac Posted July 18, 2015 Share Posted July 18, 2015 That seems a lot of work,the thing that'd worry me is that everything went back correctly! can't believe all that just to fix a fan heater,are these definitely not accessible when removing the undertrays? It is what it is I'm afraid I've never done it, but would either want help from someone that had done it before, or bite the bullet and take it to an independent specialist and pay them to do it. Link to comment Share on other sites More sharing options...
StormS2 Posted July 18, 2015 Author Share Posted July 18, 2015 This is when living in North Wales has its down sides!any recommendable specialists around Chester area?or maybe Midlands Link to comment Share on other sites More sharing options...
un1eash Posted July 18, 2015 Share Posted July 18, 2015 Phoenix motorsport in Accrington or Unit 4 in Burton. Link to comment Share on other sites More sharing options...
DanP Posted July 19, 2015 Share Posted July 19, 2015 Bear in mind that was a main dealer, and they could charge top dollar as it was going to a lease company. I didn't keep the invoice, but IIRC it was <£40 in parts, the rest was main dealer labour rates. Could you get a mate round and have a "clam off" party? Seeing the work you did with your rear diffuser panel this seems like it could be within your DIY levels, but you need two people. http://wiki.seloc.org/a/Remove_S2_front_clamshell "Clam off" party.... Like that!!! Lol I'm going to wait till winter and do the "clam off". Luckily I've got a garage. So I can take the clam off, and see what bits i need to order my leisure. Resistor pack, fan relay, alloy radiator - is there anything else I need to swap while I've got the clam off? Dan Link to comment Share on other sites More sharing options...
Martin R Posted July 19, 2015 Share Posted July 19, 2015 Rusty towing eye. Link to comment Share on other sites More sharing options...
Legacystorm Posted July 22, 2015 Share Posted July 22, 2015 Can do with clam on Link to comment Share on other sites More sharing options...
StormS2 Posted July 23, 2015 Author Share Posted July 23, 2015 Was just checking inside the car earlier and found this with what looks like 2 fuses missing??can someone who has a 111s with aircon check and see whether this is normal or not?its under the dash on passenger side Link to comment Share on other sites More sharing options...
Wildspark Posted July 26, 2015 Share Posted July 26, 2015 My 111S with A/C has exactly the same fuse holder and just 2 fuses like in your picture. Link to comment Share on other sites More sharing options...
StormS2 Posted July 26, 2015 Author Share Posted July 26, 2015 Thankyou,that rules that out then:( So this is doable with clam on? Link to comment Share on other sites More sharing options...
DanP Posted July 26, 2015 Share Posted July 26, 2015 Was just checking inside the car earlier and found this with what looks like 2 fuses missing??can someone who has a 111s with aircon check and see whether this is normal or not?its under the dash on passenger sideThe manual has a fuse layout diagram. You can check there.First time my fan went on the blink, Wriggling the appropriate fuse seemed to make a difference. https://www.eliseparts.com/products/show/61/410/electrical-relays/ Says to check the earthing before writing off he relay. Any idea what that means? Link to comment Share on other sites More sharing options...
Wildspark Posted July 27, 2015 Share Posted July 27, 2015 There are earthing points to the chassis at the front and rear of the car on the pax side. I think the front one can only be got at with the clam off, though I'm not certain about that. Presumably the fan current returns through the chassis, so the relays can be good but the fan doesn't work if the earth point is bad. Link to comment Share on other sites More sharing options...
