JJM Posted July 7, 2015 Share Posted July 7, 2015 Hi Guys Just bought an Elise S1 and while I know it will be noisy there is a loud vibration from under the driver seat at 2-3k revs where the floor pan goes under the cross members near the handbrake cover. If I put my left hand behind the seat I can feel the whole panel vibrate. Question is what can I do to cure this? Do I need to come at it from below? Cheers James Link to comment Share on other sites More sharing options...
russelld Posted July 7, 2015 Share Posted July 7, 2015 Hi James, Welcome to MLOC K series engines have an exhaust resonace around 2.5k RPM, this is normally heard as a tizz. Elise parts sell an anti tizz bracket to stop the exhaust vibration. http://www.eliseparts.com/products/show/40/742/anti-tizz-bracket/ As your floor pan is vibrating I would start off by removing both rear under trays, get the car up in the air ( axle stands or at a garage with a lifting platform ) then see if you can identify the vibration cause while someone revs the engine ( it will be difficult to simulate load conditions but it should help ). Also check all 3 engine and gearbox mountings, if these are failing it could also be the cause. If nothing is untoward bonding an anti vibration pad to the panel may cure it. Good luck Russ. Link to comment Share on other sites More sharing options...
jody391 Posted July 7, 2015 Share Posted July 7, 2015 I use a yellow smiling stress ball and wedge it under the seat, that say you can still move the seat. Jode. Link to comment Share on other sites More sharing options...
Phil S1 Posted July 7, 2015 Share Posted July 7, 2015 To rule out one possibility, does the vibration stop if you gently pull the handbrake? The linkage arrangement could be vibrating about and hitting the undertray? Link to comment Share on other sites More sharing options...
JJM Posted July 7, 2015 Author Share Posted July 7, 2015 Thanks for the feedback guys, also the vibration only seems to occur once the car has been driven for a while and well up to temp. Time to break out the socket set and deep heat for my back from scaling underneath. Link to comment Share on other sites More sharing options...
