cjwjames Posted April 7, 2015 Share Posted April 7, 2015 I currently Run the OE Bridgestone on my S2 ( I think DeanB also does the same) what is the general consensus on tyre pressure do you run them at manufacturers specified PSI. or slightly under to give a better grip ? Link to comment Share on other sites More sharing options...
DeanB Posted April 7, 2015 Share Posted April 7, 2015 I run mine at 24 front 26 rear - operating temperature though, not cold. On a track day I might go a bit lower, always measuring when hot. Link to comment Share on other sites More sharing options...
keo Posted April 15, 2015 Share Posted April 15, 2015 I read i should run them 26F 29R is this standard pressure? I don't know much yet as i have only just had the car. It feels alot better than the 31psi l around which it previously was anyway! Link to comment Share on other sites More sharing options...
Gary ZBJ Posted April 15, 2015 Share Posted April 15, 2015 26f 29r is too high 23f 25r is what i used to run mine at If they are LTS bridgestones it might be worth thinking of some new tyres, they have not been made in a long time so could be quite old Link to comment Share on other sites More sharing options...
keo Posted April 16, 2015 Share Posted April 16, 2015 Ok Gary I will drop the pressures tonight thanks Link to comment Share on other sites More sharing options...
Gary ZBJ Posted April 16, 2015 Share Posted April 16, 2015 No problem, Whilst you are adjusting the pressure have a look at the date code on the tyre, is 4 digits indicating month and year of manufacture. There is much debate over how old you can let the tyre get before performance drops, but at least you will have an idea of the age Secondly, if they are the tyres specific for Lotus, they will have LTS after where is says RE040. Again, loads of people get on fine with none LTS tyres, but you will know what is on the car Apologies if stating something you already know. Link to comment Share on other sites More sharing options...
keo Posted April 16, 2015 Share Posted April 16, 2015 No problem i didnt know about the LTS, . Had some bone hards tyres on a Civic type R once and it was horrible, they had gone off because of age. My tyres look (and feel) pretty brand new but i will check the dates. Thanks for the info Link to comment Share on other sites More sharing options...
stockhome Posted April 16, 2015 Share Posted April 16, 2015 I think Bridgestone stopped making RE040 at least five years ago. Link to comment Share on other sites More sharing options...
Wildspark Posted April 17, 2015 Share Posted April 17, 2015 The manual says 26 front 27.5 rear. One of my non-LTS tyres has 4211 as the date code. I presume that means week 42 of 2011. Link to comment Share on other sites More sharing options...
Gary ZBJ Posted April 17, 2015 Share Posted April 17, 2015 Yeah, manual states higher than I was advised by Steve Guglielmi to run mine at, I always ran them at 25r / 23f and was happy with them, no adverse treadwear. Yeah, 4211 will be week 42 of 2011. Link to comment Share on other sites More sharing options...
DanP Posted April 18, 2015 Share Posted April 18, 2015 The temperature stated in the manual works well, but some people say it gives uneven tyre wear (centre of tyre wearing more). I run standard temperatures and get pretty even wear, with track days taking more tread off the edges of the tyre to even things out. Ymmv. Link to comment Share on other sites More sharing options...
