Deanb182 Posted March 22, 2015 Share Posted March 22, 2015 Hi. My exige has recently developed an issue on cam change. As soon as it hits 6000 RPM, it engages but the shift light comes on and hits the limiter. I have narrowed this down to the coolant temp sensor, as during driving there is no reading displayed on the stack, as though its still warming up. However, if i leave it to idle the temperature will be displayed from 70c and rise to normal which allows me to rev, and drive the car to it's normal rev limit with the cam engaging as it should. The only issue is as soon as i start driving the temperature reading starts to drop and within minutes it's below 70c and disappears. The car then become restricted again. I'm going to change the coolant sensor, just wondered if anyone has every experienced this same problem? Thanks Link to comment Share on other sites More sharing options...
kieranexige Posted March 22, 2015 Share Posted March 22, 2015 I had a similar problem on the vx220 or vtec can't remember which but that was the thermostat stuck open I think. Do the heaters blow hot? Link to comment Share on other sites More sharing options...
Deanb182 Posted March 22, 2015 Author Share Posted March 22, 2015 They do indeed blow hot, even with the AC on. Link to comment Share on other sites More sharing options...
chris_h Posted March 23, 2015 Share Posted March 23, 2015 I agree sounds like a stuck open thermostat. Link to comment Share on other sites More sharing options...
russelld Posted March 23, 2015 Share Posted March 23, 2015 It does sound like the stat, but the sensor is by far the easiest to replace and try first, the stat is a PITA to get to. Link to comment Share on other sites More sharing options...
Reg Posted March 23, 2015 Share Posted March 23, 2015 If it gets up to temp standing still and drops when you're moving, it's not going to be the sender. I would be going straight for the stat. Link to comment Share on other sites More sharing options...
kieranexige Posted March 23, 2015 Share Posted March 23, 2015 Easy way to check would be to stick a piece of cardboard in the grill covering 80% and see if it holds temperature. Link to comment Share on other sites More sharing options...
