DeanB Posted January 26, 2015 Share Posted January 26, 2015 I have always thought, geek that I am, that it would be good to do a proper test day and back to back different tyre pressures, damper settings and so on to see what does what laptime. In the real world though I would suggest that 24 front and 26 rear (hot) is a good starting place for tyres. As for understeer/oversteer (wombling free?!?) remember that by reducing understeer in slower corners using, e.g, stiffer damper settings or anti roll bar settings on the front, you will make the rear of the car feel less stable in higher speed corners. Likely even shit-your-pants unstable. It is always a compromise. As I am not Lewis I prefer to sacrifice a bit of turn-in positivity at slower speeds for a more confidence inspiring rear end at higher speeds. It is worth it for the reduction in laundry bills. You can drive round a lot of the lower speed understeer by trail braking, which isn't as difficult or scary as it sounds. As a rule of thumb, if you are getting too much oversteer for your taste/ability try softening the rear and/or stiffening the front dampers. The reverse if it's understeer. And always ask yourself at what speed is your car demonstrating these characteristics? remember that a set up is always a compromise between how your car will handle on fast and slow corners. Link to comment Share on other sites More sharing options...
KurtB Posted January 27, 2015 Author Share Posted January 27, 2015 That sounds like a plan Dean, though I have another to add (scarily). You may not be Lewis, but you can steer, so what say next time I'm out on track I give you a shout and you have a go? I could mess around all day changing this and that and still be no better off. Just an idea... Link to comment Share on other sites More sharing options...
DeanB Posted January 27, 2015 Share Posted January 27, 2015 I would be glad to mate. Blyton is ideal for this kind of thing btw. Link to comment Share on other sites More sharing options...
