Alex B Posted November 25, 2014 Share Posted November 25, 2014 What's best to use? Dave Andrews recommends lecture 574 from what I've found in post by him on various sites. Locative only sets when under compression. Gav suggested blue hylomar. Is a non setting gasket. Link to comment Share on other sites More sharing options...
Phil S1 Posted November 25, 2014 Share Posted November 25, 2014 When I got the cams and verniers from Rog for mine he supplied me with a tube of the OE MG Rover sealant Link to comment Share on other sites More sharing options...
AlanS1 Posted November 25, 2014 Share Posted November 25, 2014 Alex, I have some here at my workshop if you want to use some.? Probably be here a little later than normal as I am stopping to do some work on my car. Link to comment Share on other sites More sharing options...
Martin R Posted November 25, 2014 Share Posted November 25, 2014 Alex, put as little on as possible. Its only sealing 2 machined surfaces. The tappets will rattle if you block or partially block an oilway. Link to comment Share on other sites More sharing options...
Alex B Posted November 25, 2014 Author Share Posted November 25, 2014 Alex, I have some here at my workshop if you want to use some.? Probably be here a little later than normal as I am stopping to do some work on my car. Cheers Al, I picked some blue hylomar up today. But I'm also on call tonight so shouldn't really stray too far from the house. Alex, put as little on as possible. Its only sealing 2 machined surfaces. The tappets will rattle if you block or partially block an oilway. Yup Gav mentioned using a very tiny amount. Link to comment Share on other sites More sharing options...
AlanS1 Posted November 25, 2014 Share Posted November 25, 2014 No problem Alex. Same as what Martin said, do not put much on at all. I used a small radiator roller to apply mine. Be careful using Hylomar, from memory it's quite thin and runny. It would be very easy to use to much. Link to comment Share on other sites More sharing options...
Alex B Posted November 25, 2014 Author Share Posted November 25, 2014 No problem Alex. Same as what Martin said, do not put much on at all. I used a small radiator roller to apply mine. Be careful using Hylomar, from memory it's quite thin and runny. It would be very easy to use to much. Thanks for the tip Al. Link to comment Share on other sites More sharing options...
@ndy Posted November 25, 2014 Share Posted November 25, 2014 Don't use Hylomar on the cam ladder, Only use the Rover OE sealant or Loctite 574 and as Martin says use as little as possible. Hylomar is used when re-seating the liners. Link to comment Share on other sites More sharing options...
Alex B Posted November 26, 2014 Author Share Posted November 26, 2014 Don't use Hylomar on the cam ladder, Only use the Rover OE sealant or Loctite 574 and as Martin says use as little as possible. Hylomar is used when re-seating the liners. Good job I've read this before doing so then. Looks like I'll be hunting for some loctite 574 Today. Link to comment Share on other sites More sharing options...
