@ndy Posted November 15, 2014 Share Posted November 15, 2014 I will be building a new K series engine over the next month or so wondered if the EP baffled sump would be a good idea? My car is mostly used on track these days so my questions are - Is a sump baffle really required in K series in an Elise ? Is the Eliseparts baffle OK, I see some people have had problems ? What are the downsides of fitting a sump baffle ? Cheers Andy. Link to comment Share on other sites More sharing options...
dobbo Posted November 15, 2014 Share Posted November 15, 2014 Questions on whether or not it (or the DVA) on should be welded in. General consensus is that it shouldn't. Can't see a downside if you have the engine stripped anyway. Should reduce the risk of losing oil on hard left-handers at least. Link to comment Share on other sites More sharing options...
Martin R Posted November 15, 2014 Share Posted November 15, 2014 Andy, if you are doing it yourself i would fit one. AFAIK its a DVA design. Get it from him and ask for tips on fitting? I would be very reluctant to weld one in. Edit, are you going the whole hog with this one? Link to comment Share on other sites More sharing options...
@ndy Posted November 15, 2014 Author Share Posted November 15, 2014 I'll give Dave a call on Monday and have a chat....... Cheers guys Link to comment Share on other sites More sharing options...
Alex B Posted November 16, 2014 Share Posted November 16, 2014 I'll give Dave a call on Monday and have a chat....... Cheers guys Post up your findings please Andy as I'm also interested in fitting a n EP sump baffle. Link to comment Share on other sites More sharing options...
Steve J Posted November 16, 2014 Share Posted November 16, 2014 Anyone tracking a car I would say a baffled sump is essential. Link to comment Share on other sites More sharing options...
@ndy Posted November 16, 2014 Author Share Posted November 16, 2014 Post up your findings please Andy as I'm also interested in fitting a n EP sump baffle. Will do Alex....... Link to comment Share on other sites More sharing options...
fentuz Posted November 17, 2014 Share Posted November 17, 2014 Looking a James' report on Seloc, the welded version seems to suffer of fatigue failure. On elises, providing the oil lever remains at max, it should be fine. in the elise, the baffle doesn't seem to be an issue however, it the caterhams, it can be. I've done a fair amount of trackdays without issues. Last year, mindful of the low risk of oil starvation, instead of fitting a baffled sump, I put a low oil pressure warning sensor as fitted on race cars (radical for example); it's a 21 psi rather than the EP 13psi (STD rover is 7 or 8 from memory). Due to the aluminium chassis and "lovely" earthing on elises, it starts to blip @ 28/30psi. So when at idle, it blips but as soon as you rev above 1200rpm, it doesn't. On Track if will show is the oil pressure goes down in fast corners before damages happen. Link to comment Share on other sites More sharing options...
@ndy Posted November 17, 2014 Author Share Posted November 17, 2014 So I spoke with Dave who said that all the failures he knows about were due to poor installation, either due to them being welded in or welded together or clearance issues with the sump as occasionally some minor fettling may be required especially on later sumps. He has supplied to many racers/engine builders who have had no problems He says they can be a bit fiddly to fit if working under the car but apart from that all OK so I cant see the downside and will be fitting one in my new engine. I have the low oil pressure sensor mentioned above and sometimes see it flicker on tick-over after a hot session on track. Link to comment Share on other sites More sharing options...
Alex B Posted November 18, 2014 Share Posted November 18, 2014 So I spoke with Dave who said that all the failures he knows about were due to poor installation, either due to them being welded in or welded together or clearance issues with the sump as occasionally some minor fettling may be required especially on later sumps. He has supplied to many racers/engine builders who have had no problems He says they can be a bit fiddly to fit if working under the car but apart from that all OK so I cant see the downside and will be fitting one in my new engine. I have the low oil pressure sensor mentioned above and sometimes see it flicker on tick-over after a hot session on track. So what's you decision Andy ? Link to comment Share on other sites More sharing options...
@ndy Posted November 18, 2014 Author Share Posted November 18, 2014 So what's you decision Andy ? Sump baffle ordered from Eliseparts..... Price was the same from DVA Link to comment Share on other sites More sharing options...
Alex B Posted November 22, 2014 Share Posted November 22, 2014 Sump baffle ordered from Eliseparts..... Price was the same from DVA I think I'm gonna give fitting a sump baffle a miss for now. As I've read a few horror stories with regards poor fitting, and I know what my luck is like. Link to comment Share on other sites More sharing options...
@ndy Posted November 22, 2014 Author Share Posted November 22, 2014 I think I'm gonna give fitting a sump baffle a miss for now. As I've read a few horror stories with regards poor fitting, and I know what my luck is like. I had the same fears, However after speaking with Dave these have been alleviated.... As with anything, If fitted incorrectly you will have problems Link to comment Share on other sites More sharing options...
