fentuz Posted November 13, 2014 Share Posted November 13, 2014 I know the feeling... Other than a small battery, I can't how I can remove more weight without drastic cut up and comfort removal... Link to comment Share on other sites More sharing options...
MilesH Posted November 13, 2014 Share Posted November 13, 2014 I have a trickle charger. if im not using the car i will disconnect it. 2 mins with a 10mm spanner. The Oddessy are designed to Keep the charge for a looong time disconnected. we will see I'm sure you know already, but just incase, you need to make sure the trickle charger you use is suitable for the dry cell type battery that the Odyssey is. I know most half decent chargers are, just not the aldi etc 'cheaper' ones. I managed to destroy my last one with the wrong charger! Expensive mistake! Also, I was advised they don't cope well by being on constant trickle charge. I was advised to charge it to full and then disconnect the earth lead. Hope you're well Martin? Link to comment Share on other sites More sharing options...
Martin R Posted November 13, 2014 Author Share Posted November 13, 2014 Miles, i have that all covered. We need to meet soon. I may return to a bit of sprinting need year if you need a few tips Link to comment Share on other sites More sharing options...
chris_h Posted November 13, 2014 Share Posted November 13, 2014 The LiFEPO4 can't be trickle charged Yes they can, you just need the correct type of charger (like you also need to do with the AGM batteries). Link to comment Share on other sites More sharing options...
Lunner Posted November 14, 2014 Share Posted November 14, 2014 Yes they can, you just need the correct type of charger (like you also need to do with the AGM batteries). Can be charged with standard Lead-acid battery charger. To ensure compatability with your motorcycle, ensure peak charging voltage doesn't exceed 14.4V. CAUTION : must not be used with a 'maintenance' or trickle charger. Link to comment Share on other sites More sharing options...
chris_h Posted November 14, 2014 Share Posted November 14, 2014 Yes but you can buy special chargers for lithium batteries including from Shorai that can left connected all the time. http://www.carrotcycles.co.uk/index.php?_a=product&product_id=1583 You just can't use a standard trickle charger, same as you can't with an oddessy AGM type battery. Link to comment Share on other sites More sharing options...
Lunner Posted November 19, 2014 Share Posted November 19, 2014 Fair enough, did think it was a little odd Link to comment Share on other sites More sharing options...
