Alex B Posted November 10, 2014 Share Posted November 10, 2014 As most of you know I managed to kill my S1 Elise at Blyton park just over a month ago. Well I've sourced a new engine from Maidstone sports cars. New engine specs: 160 VVC spec engine Quaife LSD 52mm TB 4branch exhaust Ported head Running uprated VVC cams (being removed) While the engines out I plan on cleaning the bay up and replace some shoddy wiring. I also have one or two other mods planned while rebuilding. Started the dismantling on Saturday Managed to get the clam off (first time is done it) little awkward on your own but not impossible, also labeled up all the wiring. Alternator feed has seen better days: What is this? And this black box Only managed an hour on the car tonight due to work. Fuel and water disconnected just drive shafts to do and then it's ready to come out. Suspicious bit if fuel piping found tonight. Was held together with sticky tape. Link to comment Share on other sites More sharing options...
jody391 Posted November 10, 2014 Share Posted November 10, 2014 Inertia switch bud. Link to comment Share on other sites More sharing options...
Martin R Posted November 10, 2014 Share Posted November 10, 2014 Indeed it is. Alex wear some gloves for the non fiddly bits. Good luck Is that the pipe that comes from the roll over valve and goes to the charcole canister. Dont throw away the old VVC exhaust cam. I may have a plan. Link to comment Share on other sites More sharing options...
Dr H Posted November 10, 2014 Share Posted November 10, 2014 Inertia switch bud. What you mean it will grow lots of little inertia switches? Link to comment Share on other sites More sharing options...
Martin R Posted November 10, 2014 Share Posted November 10, 2014 Alex, im going up the electroplaters this week with a load of bolts etc. You can have what you need. A new engine should never be fitted with old grubby stuff. Let me have the old ones. Link to comment Share on other sites More sharing options...
jody391 Posted November 10, 2014 Share Posted November 10, 2014 Ha ha only if turned on!! Lol Link to comment Share on other sites More sharing options...
Martin R Posted November 11, 2014 Share Posted November 11, 2014 On the bright side the wishbones look ok. You might as well do them as well Link to comment Share on other sites More sharing options...
Alex B Posted November 11, 2014 Author Share Posted November 11, 2014 Alex, im going up the electroplaters this week with a load of bolts etc. You can have what you need. A new engine should never be fitted with old grubby stuff. Let me have the old ones.Cheers Martin! I may well take you up on this. Although the new engine is spotless as are all the bolts attached to it. Yes it is the pipe that goes up to the charcoal canister. Been cut and bodged together. Don't happen to have a spare do you? Link to comment Share on other sites More sharing options...
Martin R Posted November 11, 2014 Share Posted November 11, 2014 Alex, no unfortunately. Link to comment Share on other sites More sharing options...
russelld Posted November 11, 2014 Share Posted November 11, 2014 Good work Alex You have got further than I did on Sunday. I had a 3 hours on mine and have got it nearly to the point of taking off the rear clam. Link to comment Share on other sites More sharing options...
John FISH Curtis Posted November 11, 2014 Share Posted November 11, 2014 I had a 3 hours on mine and have got it nearly to the point of taking off the rear clam. Erm, what you broken now Russ? Link to comment Share on other sites More sharing options...
Alex B Posted November 11, 2014 Author Share Posted November 11, 2014 With any luck the engine will be out tonight. Need to order cam belt kit + water pump. Oil filter Oil. Thermostat And a few other little bits n pieces. Link to comment Share on other sites More sharing options...
AlanS1 Posted November 11, 2014 Share Posted November 11, 2014 Both my clams off and engine have been out since Friday and i didn't start till Thursday What you messing about at? Might not be back together as quick as yours as i will be doing more work while out. Link to comment Share on other sites More sharing options...
Martin R Posted November 11, 2014 Share Posted November 11, 2014 Alex, has the air con pulley been machined off on the crank pulley? Link to comment Share on other sites More sharing options...
Alex B Posted November 11, 2014 Author Share Posted November 11, 2014 Alex, has the air con pulley been machined off on the crank pulley? No it hasn't Martin. Both my clams off and engine have been out since Friday and i didn't start till Thursday What you messing about at? Might not be back together as quick as yours as i will be doing more work while out. I don't have any staff to set to work on mine! Link to comment Share on other sites More sharing options...
