Lee Posted August 26, 2014 Share Posted August 26, 2014 After pressing the button to set the alarm, the doors lock and indicators flash as normal. But then after a few seconds I get a continuous tone.... Any ideas what is going on? Link to comment Share on other sites More sharing options...
@ndy Posted August 26, 2014 Share Posted August 26, 2014 Mine does this if it can't arm, Is there a door open, engine cover or front access cover, possibly a faulty switch ? Link to comment Share on other sites More sharing options...
Lee Posted August 26, 2014 Author Share Posted August 26, 2014 Opened/closed both doors and engine cover to check..... maybe i will have a fiddle with the switches. Link to comment Share on other sites More sharing options...
@ndy Posted August 26, 2014 Share Posted August 26, 2014 Also check the connection to the interior sensor mounted between the seats on the rear bulkhead, it's a simple plug similar to a telephone RJ11 type Link to comment Share on other sites More sharing options...
chris_h Posted August 26, 2014 Share Posted August 26, 2014 Front drivers side panel when I had this problem. Link to comment Share on other sites More sharing options...
Lee Posted August 27, 2014 Author Share Posted August 27, 2014 Nothing seems to have worked as yet.... changed the batteries in the fob too. Door switches activated the interior light OK. Link to comment Share on other sites More sharing options...
Lee Posted September 5, 2014 Author Share Posted September 5, 2014 Quick question.... does the engine cover activate the interior light when opened? Link to comment Share on other sites More sharing options...
chris_h Posted September 5, 2014 Share Posted September 5, 2014 Shouldn't do Link to comment Share on other sites More sharing options...
Lee Posted September 5, 2014 Author Share Posted September 5, 2014 ahhh just thought it would be an easy way to see if the connector was working. I am right in assuming that if both doors operate the light then the alarm sensors should be working? So I can say it the engine cover that isn't. Link to comment Share on other sites More sharing options...
chris_h Posted September 5, 2014 Share Posted September 5, 2014 Or the front acces panel Link to comment Share on other sites More sharing options...
Lee Posted September 5, 2014 Author Share Posted September 5, 2014 There's an alarm sensor under the front access panels on the S2 Exige? Are they on both sides? Link to comment Share on other sites More sharing options...
chris_h Posted September 6, 2014 Share Posted September 6, 2014 Yes that was the one that was faulty on mine. Link to comment Share on other sites More sharing options...
Lee Posted September 6, 2014 Author Share Posted September 6, 2014 Drivers side front access off, sensor unplugged, plugged back in, alarm works Thanks, Link to comment Share on other sites More sharing options...
chris_h Posted September 6, 2014 Share Posted September 6, 2014 I did tell you on the 26th August above! Link to comment Share on other sites More sharing options...
Lee Posted September 6, 2014 Author Share Posted September 6, 2014 OK OK, only just round to taking the access panel today Link to comment Share on other sites More sharing options...
