Postman..,
Alex B
  • Replies 33
Haha, nope that was for opening the box as my knife had ran away.
There in belts on and timing next.
Yeah unfortunately I've been mucked around with parts for the past two weeks.
Now I'm struggling with timing. Best get the push bike out for Chatsworth.
Chop, chop. You have done the hard bit :)
I've got the new cams timed up via the crank.
It all moves as it should no fowling by hand so I Decided I'd give it ago at starting before fine tuning the cam timings it's cranks n tries to fire but also no K series roar.
Is I'm thinking either timing it miles out or the map needs some tweaking.
The timing up using dti's is quite daunting so thought I'd leave it for tomorrow afternoon when I'm more awake.
Welcome to my world. I presume you have fitted the Emerald at the same time? The new ones will allow you to keep the IACV. Try putting your foot down on the accelerator slightly when trying to start. If it then runs the IACV probably wants setting up in the Emerald. Also make sure the immobiliser is disabled in the programme. Good luck.
